ospf summarisation
amms68958
How does an ABR generate the cost for ospf summarised routes..?
6 Replies 6
Richard Burts
Ammavan
According to RFC 2328 when an ABR summarizes a range of routes it examines the routes to be summarized and advertises the highest cost of the individual routes.
Rick
Rick
Rick,
Thats a good answer.
Can a user anyway manipulate the cost of the summarised route,in this case..?
Thanks in advance,
Ammavan
Other than being able to use the ospf cost interface command to manipulate the metric of the individual routes (make some other route have a higher cost, or make the current highest cost lower) I am not aware of any way that you can manipulate the cost of the the summarized route.
Rick
Rick
Rick/Ammavan,
My observation has been that IOS is not compliant with RFC2328 in this area. The metric used for the summarised routes by the ABR is the *lowest* of all the metrics of the routes being summarised.
Also, there *is* a way to manually set the summary for the summarised route using:
area range [advertise | not-advertise] [cost cost]]
Hope that helps - pls rate the post if it does.
Paresh
Just another note: the cost keyword was added in IOS 12.2
Paresh
Paresh
Good observation.
Rick
Rick
