ospf Summarize routes
feroz syed
Level 3
Level 3
its ospf network, i'm facing some problem when i try to summarize routes between from area0 to area 1, Router5 placed in area0 its has couple of loop address and router 2 (ABR) want to summarize those address in to area 1.
here is the error message when i try to advertise this routes
R2(config-router)#area 1 range 172.12.1.0 255.255.240.0
% OSPF: Inconsistent address/mask 172.12.1.0/20 for area range
   172.12.0.0/24 is subnetted, 6 subnets
O       172.12.1.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
O       172.12.4.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
O       172.12.5.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
O       172.12.6.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
O       172.12.8.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
O       172.12.10.0 [110/65] via 10.1.246.5, 00:06:45, Serial1/0
3 Accepted Solutions
Rolf Fischer
Level 9
Level 9
you have to summarize those networks in Area 0.
area range command:
area-id: Identifier of the area about which routes are to be summarized. It can be specified as either a decimal value or as an IPv6 prefix.
Rolf
You cannot summarise routes in OSPF within the same area. You can summarise -
1) on the ASBR when you inject routes into your OSPF domain
and
2) when you pass routes from one area to another area.
Jon
Instead of 172.12.1.0 255.255.240 try 172.12.0.0 255.255.240.0.
Jon
8 Replies 8
Rolf Fischer
Level 9
Level 9
area range command:
Rolf
Router 5 already placed in Area0, can we summarize routes inside the area ?
and
Jon
You need to use the area range command on the ABR to summarize to other areas:
R2(config-router)#area 0 range 172.12.1.0 255.255.240.0
Inside an area you can't summarize or filter, because the LSDBs of all routers within an area have to be the same. This is, among scalability and limiting the scope of the SPF algorithm, one of the main concepts of link-state routing protocols hierarchy.
if you see the diagram, router 2 is ABR for area 1 its connected to area 0 and area 1,
But i mention wrong area id just saw the fischer post.
if its work i ll close this post .
But stil the same error showing even i change the area id from1 to 0
Jon
Thanks for the correction working
