OSPF THE CHOICE
divine007
Hi All,
attached below is the Design i have in place.
what actually in place are static routes and a GRE IPSEC tunnel in place with static routes
We have sites in each town but we have 2 principal towns or sites.But we BGP with our uplink provider
  have decised to go with OSPF to make routing dynamic
starting with IBGP to interconnect p2p with each site then ospf, before advertising static routes into or activation in full
Looking at the High Level Design
which equipment consist of cisco 7200routers, 4550switch , 2800 routers and also a Bras Mikrotik will be included in it.
I will like to know the difficuties that i may encounter and also some tips
paolo bevilacqua
Do you have the expereince, skills and certification for such a project?
Otherwise it would be better to engage a reputable consultant or certified Cisco partner, to avoid aggravation and get sure results.
Am a Cisco CCNA CCNP CCDA and CCIE R&S written.
I just wish to share experience with others on this site
divine007
OSPF deployment is going great.
Now i wish to redistribute my static routes into OSPF and maybe also do it by summarising because they are really much
i need to be carefull some of my public routes are routed via BGP to my provider to the internet.
Do someone have an opinion on doing this
