ospf timers
shiva_ial
router1>sh ip route 10.138.122.0
Routing entry for 10.138.0.0/16
Known via "ospf 65040", distance 110, metric 302, type inter area
Last update from 10.132.253.22 on GigabitEthernet0/1, 07:51:38 ago
Routing Descriptor Blocks:
* 10.132.253.22, from 10.132.246.8, 07:51:38 ago, via GigabitEthernet0/1
Route metric is 302, traffic share count is 1
hi everybody,
i want know the timing mentioned in ip route (07:51:38) refreshes very often,
sometimes it start from 0:00:00 and be there for 15 seconds sometime for a minute
what does that mean
topology changes(LSA'S)
hello updates
Rgds
shiva
Hi Arav,
The Reason output can be interpreted as follows:
Record of reasons causing SPF to be executed:
•N A change in a network LSA (type 2) has occurred.
•R A change in a router LSA (type 1) has occurred.
•SA A change in a Summary autonomous system boundary router (ASBR) (SA) LSA has occurred.
•SN A change in a Summary Network (SN) LSA has occurred.
•X A change in an External Type-7 (X7) LSA has occurred.
Rick, after labing this around i consolidated that interArea routes causes SPF execution (interarea and external routes result in partial SPF calculations) and in the output of the show ip ospf statistics it is tagged as SN:
PE-4#sh ip ospf statistics
OSPF Router with ID (150.1.4.4) (Process ID 1)
Area 0: SPF algorithm executed 6 times
Summary OSPF SPF statistic
SPF calculation time
Delta T Intra D-Intra Summ D-Summ Ext D-Ext Total Reason
23:48:04 0 0 0 0 0 0 0 R,
23:47:54 0 0 0 0 0 0 0 R,
23:42:27 0 0 0 0 0 0 0 R, N,
02:36:09 0 0 0 0 0 0 0 R,
01:51:29 0 0 0 0 0 0 0 R,
00:00:18 0 0 0 0 0 0 0 R, SN,
BR,
Mohammed Mahmoud.
16 Replies 16
mohammedmahmoud
Level 11
Level 11
Hi Shiva,
This timer specifies the last time the route was updated (from hours:minutes:seconds).
By design, OSPF requires LSAs to be refreshed as they expire after 3600 seconds. You can check out "ip ospf flood-reduction" - Suppresses the unnecessary flooding of LSAs in stable topologies - In other words suppresses the LSA refresh (DNA LSA) - Only LSAs exchanged are in case of topology change.
[edit] Sorry i drifted with the explanation, Kevin's reply is more direct.
BR,
Mohammed Mahmoud.
Kevin Dorrell
Level 10
Level 10
Shiva,
07:51:38 means the route has been stable for 7 hours 51 minutes and 38 seconds. The timing starts on topology changes. If you are seeing values very much smaller, then you probably have routes flapping.
Kevin Dorrell
Luxembourg
hi kevin,
thanks for your reply
i have seen timer refreshing every 15 seconds
to 30 seconds(means when timer reaches 15 seconds goes back to 0 and again starts)so is it ok on normal scenario or it shouldn't be
pls clarify terminology related in detail, because i am seeing timer refreshing every 15 seconds which means there could be topology changes occuring causing the timer to restart
will it include hello update,I could not find any topology changes in my network every 15 seconds
shiva
There seems to be some confusion about the OSPF LSAs which are sent on a periodic basis to ensure the consistency of the OSPF data base and the LSAs that are sent when a link changes state. Neither the periodic LSAs to ensure consistency nor the Hellos cause a calculation of the SPF while the LSAs for a link state change do cause a calculation of the SPF. I believe that what you are seeing indicates that the route for 10.138.0.0/16 was involved in an SPF calculation 7 hours ago because the link changed state.
You can check on this by looking at show commands to see how many times the SPF calculation has occurred and you might consider running the debug for ospf spf to see it running.
[edit] having looked more closely at the original post I see that the route is an inter-area summary route. An update of this would not cause an SPF calculation on your router but probably did cause an SPF calculation on the router where the route originated.
A slightly different suggestion about how to check on this would be to run debug ip rout and look at how often your routing table is being updated.
Rick
Rick
Hi Rick,
Always a fortune having you around :), totally agree with you about the SPF recalculation, Type 3 LSA should only cause SPF recalculations in its original area, this means that most probably the area that this route belongs to is suffering topology changes, we can check this via the "show ip ospf statistics".
BR,
Mohammed Mahmoud.
Rick, as usual, real nice observation about the inter-area summary route and hence the non-requirement of an SPF calculation on this router.
Mohammed, a very useful command that shows the ospf statistics. However, how do we read the 'Reason' column in the command output ?
Cheers
Arav
Hi Arav,
BR,
Mohammed Mahmoud.
From your addition placed in parentheses, it seems that you agree with my earlier post :-)
Maria,
I edited my post before seeing your post :) i think this makes me an honest believer of your opinion :)
BR,
Mohammed Mahmoud.
Ok, Mohammed, that's fine and I am glad we have a genuine agreement, because I really like the people in this forum and wouldn't like it to be any other way :-)
Edit: By the way, the output you posted is very useful for future reference.
Maria, thank you very much, i wouldn't dare to ask about the other way :) but rest assured that around here we only have one way.
Hi Mohammed, That's v helpful. You get a 5! I couldn't make out what SA was. But now I can, from your post.
And I reckon D-Intr and D-Summ Ext7 & D-Ext7 from the command output 'show ip ospf stat detail' just mean Database-IntraArea and Database-Summary routes for NSSA external routes respectively. Correct me if I am wrong. And your exercise about the partial SPF sounds reasonable.
cheers
Arav
hi everyone,
(especially Richard burts & Mohammed)i have to thank you,since the answer from you to the posts were very detail and easy understanding.
everyone in this forum gives a wonderful solutions making this forum """"Rocking"""""
rgds
shiva
shiva
Thank you for the compliment. It is gratifying to know that my posts have been helpful.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
