OSPF to BGP redistribution issue
dariopalermo
Hi guys,
I'm trying to fix this situation:
Router P (provider) has to link, one to Router A (10G) and the other to Router B (1G). On both links there is an OSPF router 50 set up to publish routers from the providers to the internal routers. Router A and B exchange routes via BGP.
I want to have the router A path (10G) in the routing table of both routers.
To make this happen I tried to  put distance, on router B, 255 in the router ospf 50 config to make the router prefer the bgp received route from router A over the ospf route received by router P.
This works until router A stop publishing the routes... at that moment router B puts into it's routing tables the ospf received routes and that is just fine... but when router A lino to router P goes back online router B sticks with the ospf routes.
Any suggestion? Thanks.
Bye, Dario
rishrapsody1
Can you please share ospf and bgp config of both router A and router B.
Also, please share 'show ip route <prefix>' and 'show ip bgp <prefix>' on router B for destination network.
seems like you have ospf to bgp redistribution enabled on router B as well.
IGP when redistributed to BGP sets weight has 36768 and thus will not let other path to get preferred.
Option is to set higher wieght for router A on router B. i.e neighbor <router A ip> weight 40000
Jon Marshall
Are you redistributing OSPF into BGP ?
If so check the weight values in the BGP routing table on router B when it has taken over.
Jon
dariopalermo
Sorry for the delay guys, and thanks for replying.
The issue was related to the "order of events": when switch B did the redistribuition into BGP of the incriminated route before receiving it from router A, it discarded the latter.
The solution was to make router A and B neighbors in the OSPF 50 area (I connected the 2 over a new p2p link).
Bye,
Dario
