ospf type 5 prefix and bgp
anastasiou82
Hi everyone.
The last days i have been struggling with the following case:
Lets assume that we have two directly connected routers R1 ----> R2 . Among them there is  eBGP Peering. R2 advertises some prefixes to R1 through BGP. Moreover on R1 i have configured some static routes as well as i have
redistributed
those routes into ospf
(redistribute static)
on R1.  When the eBGP Peering is down, i am able to see the
redistributed
static routes as ospf type 5 (
show ip ospf
database summary). But, in case where eBGP peering is up, ospf type 5 routes are removed from ospf database.
Could someone explain me why this happens ?
Thanks a lot,
Nikos
the reason is
redistribution
happens through routing table. If there is no route in routing table with
redistributing
protocol, then it can not be
redistributed
to another protocol.
In your case, you have static, ospf and BGP. You learn the same routes from BGP and static. When BGP is UP, routes installed to routing table as BGP route. Since you don't have BGP>OSPF
redistribution
you don't see any external
(redistributed)
route in OSPF (type5).
When BGP is down, BGP routes are gone from routing table and now for prefixes static routes are installed. You have
STATIC> OSPF
thus rotues are
redistributed
and you see type5 LSA for external prefixes.
HTH,
28 Replies 28
That not complete story R must ibgp with other router which make this issue
anastasiou82
The static routes and the routes which are advertised over eBGP are the same.
 Do you have
redistribute
static on BGP  ?
Yes on R1. Essentially the static routes on R1 are advertised over eBGP from R2
This can be due the protocol preference as router selects the route with the highest preference. eBGP preference is 255 while OSPF is 10.
when the BGP is down the OSPF routes is installed but when eBGP come up , it has the preference
Jul 1 16:33:18.246: RIB Redist, Topo Base, dest x.x.x.x, mask 255.255.224.0, Down
what was that sorry?
The message i get (
show ip ospf
events) when the eBGP peering goes up
Run this command with and without the BGP:
show ip ospf X  rib redistribution x.x.x.x
I will check it. Thanks al lot Flavio
You´re welcome.
 But, it seems it is related to protocol preference.
can I see config of R1
R1-R2
both have eBGP and in same time there is OSPF between two routers ?
If Yes then eBGP have AD=20 and it prefer than OSPF=110
no, R1-R2 have only eBGP peering.  R1 has ospf peering with other router.
OK your static route have AD upper than 20 ?
show me config and show me show ip bgp and show ip route
