BGP AS Path Filtering vs Prefix Based Route Filtering
nwekechampion
Level 3
Level 3
Hi Guys,
Can someone please  provide a use case of when to use
AS-PAth filtering vs Prefix
based filtering in BGP?
I have use case for
AS-Path
as below (not sure if I am on the money):
AS-Path prepending
Avoid Transit AS
AS-set Aggregation for loop prevention
As-Set Aggregation Suppression
Champ
M02@rt37
Hello @nwekechampion,
AS-Path filtering
involves manipulating the
AS-Path attribute
of BGP routes. It allows you to control the path selection and routing decisions based on the
AS-Path
information. Here's a specific use case for
AS-Path filtering:
--Traffic Engineering: You can use
AS-Path prepending
with
AS-Path filtering
to influence the inbound routing decisions of other ASes. By adding your AS number multiple times to the
AS-Path attribute
of your advertised routes, you can make your paths appear less desirable and encourage traffic to take alternative paths. This technique is commonly used for load balancing and traffic engineering purposes.
For example, if you have multiple links to a neighboring AS, you can prepend your AS number multiple times to the
AS-Path attribute
of routes advertised through a specific link. This makes the path through that link less attractive, thus diverting traffic towards other links.
Prefix-Based Filtering: Prefix-based filtering,
also known as route filtering or route
prefix
filtering, involves filtering BGP routes based on their
prefix
information (network IP addresses). Here's a specific use case for
prefix-based filtering
--Blackholing or 'Null Routing': In some scenarios, you may want to discard or drop traffic destined for a specific
IP prefix.
This could be due to security reasons or to mitigate DDoS attacks. By using
, you can configure your BGP router to discard any incoming traffic that matches the specified
IP prefix.
This effectively null routes the traffic, preventing it from reaching the intended destination.
For example, if you want to drop all incoming traffic destined for a specific IP range, you can apply a
prefix-based filter
to your BGP router, specifying the network
prefix
you want to block. Any traffic matching that
prefix
will be discarded, protecting your network from potential threats.
Best regards
5 Replies 5
There are several reasons to use either. The use different criteria. One is
prefix
based and one is
AS path
based -  here is an example of each:
AS-Path Filtering
- filters all routes from the AS being denied - I dont want any routes from this specific  AS
Lets say you have a router (R1) connected to 2 eBGP Autonomous Systems
G0/0 - connected to AS 100
G0/1 - connected to AS 200
Well when the router R1 learned routes from the ISP in AS 100 it will turn around and advertise those routes out to ISP at AS 200 - that means the outside internet now sees it can reach other internet routes through your router. Not good. So if you use out bound AS filtering that says only advertise my local AS router routes out to AS 200 then you wont be used as a transit router.
Prefix
based filtering
- filters on the the
prefixes
defined in the filter list -I dont want the 10.10.10.0/24
prefix
sent to me so Ill block it with a
prefix filter
If I am learning a
prefix
from 2 sources maybe I only want to use a specific way out
Just depends on what the requirement is
-David
M02@rt37
AS-Path filtering
AS-Path attribute
AS-Path
AS-Path filtering:
AS-Path prepending
with
AS-Path filtering
AS-Path attribute
AS-Path attribute
prefix
prefix
IP prefix.
IP prefix.
prefix-based filter
prefix
prefix
Best regards
nwekechampion
Level 3
Level 3
Thanks guys.. I think I get the idea now.
AS ==> filter
for whole AS
Prefix ==> filter
for specific
prefixes
from AS(AS's)
