ospf type 5 prefix and bgp
anastasiou82
Hi everyone.
The last days i have been struggling with the following case:
Lets assume that we have two directly connected routers R1 ----> R2 . Among them there is  eBGP Peering. R2 advertises some prefixes to R1 through BGP. Moreover on R1 i have configured some static routes as well as i have
redistributed
those routes into ospf
(redistribute static)
on R1.  When the eBGP Peering is down, i am able to see the
redistributed
static routes as ospf type 5 (
show ip ospf
database summary). But, in case where eBGP peering is up, ospf type 5 routes are removed from ospf database.
Could someone explain me why this happens ?
Thanks a lot,
Nikos
28 Replies 28
Yes,
Is upper than 20.
then friend your make LOOP,
redistribute
static into eBGP -> AD will be 20
and then
redistribute
static to OSPF,
the OSPF see eBGP not static route and hence the lsa5 disappear
you can change static route AD (only one for test) and check OSPF LSA5
or you can change the eBGP AD
I prefer change AD of static
The
redistribution
exist only into OSPF. Just changed the metric for that static route lower than 20 (eBGP AD) and the route remains on ospf database. Running
show ibgp
i see that this prefix has
r>
(rib failure). Thus the AD is the point i think. Is that setup correct or not ?
Thanks for your time
there is iBGP or eBGP?
eBGP
Running
show ibgp
r>
(rib failure)<<- this typo I think
show ip bgp
i mean. ok i will send you the config
show me the config of R1 and R2
thanks
MHM
You select solution same what I mention before' that OK
But I need to see config' I need to know why
bgp show rib
failure.
If you can
MHM
Hello
@anastasiou82 wrote:
The static routes and the routes which are advertised over eBGP are the same.
So as I stated previously with BGP having a lower seed metric then ospf that's why you only see those
redistributed
static in ospf as a type 5 as/when the bgp peering is down
Kind Regards
Paul
Hello
Sounds like those static routes being
redistributed
into OSPF are also being advertised via BGP and with BGP having a lower seed metric then ospf that's why you only see those
redistributed
Kind Regards
Paul
"Sounds like those static routes being
redistributed
into OSPF are also being advertised via BGP "
Correct!
the reason is
redistribution
happens through routing table. If there is no route in routing table with
redistributing
protocol, then it can not be
redistributed
to another protocol.
In your case, you have static, ospf and BGP. You learn the same routes from BGP and static. When BGP is UP, routes installed to routing table as BGP route. Since you don't have BGP>OSPF
redistribution
you don't see any external
(redistributed)
route in OSPF (type5).
When BGP is down, BGP routes are gone from routing table and now for prefixes static routes are installed. You have
STATIC> OSPF
thus rotues are
redistributed
and you see type5 LSA for external prefixes.
HTH,
@anastasiou82  friend still waiting the config, I need to see why prefix learn from eBGP and static route, and config of OSPF.
I need to know
next-hop
of static route and eBGP neighbor IP.
thanks
MHM
