10-13-2019 10:10 AM
I have two N9Ks connected to each other with OSPF running between them using unnumbered loopbacks. If I go to either switch and do a show ip route x.x.x.x (to it's peer) I get two possible candidate routes. Everything works fine and I can ping my neighbor but I noticed that the second entry has an 'am' after the timestamp. What does this represent?
S1# sho ip route 192.168.0.3 IP Route Table for VRF "default" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 192.168.0.3/32, ubest/mbest: 1/0 *via 192.168.0.3, Eth1/1, [110/41], 00:00:03, ospf-OSPF_UNDERLAY_NET, intra via 192.168.0.3, Eth1/1, [250/0], 00:20:10, am
Thanks!!
Solved! Go to Solution.
10-13-2019 11:04 AM
am is the adjacency manager. Routes inserted by the adjacency manager have an administrative distance of 250.
10-13-2019 11:04 AM
