OSPF
when using leased lines on the internet there is no need to use GRE tunnels to exchange dynamic routing protocols on the internet like OSPF ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It depends on what you're doing.
Often a line to the Internet only uses a default route.
If you run a VPN overlay across the Internet, often that will run an IGP, such as OSPF, within it.
If you and ISP actually dynamically route, generally BGP is used.
Ganesh Hariharan
Agreed with Joseph comment..
With having LL for internet connection either you can run static or dynamic routing protocol (mainly BGP) with ISP.
IGP at the edge is only used when you are thinking GRE over IPSEC with OSPF.
Hope it Helps..
-GI
