OSPF
abdul.qadir5001
Howto avoid OSPF routing loops. When i google it then i come to know that
"The loop avoidance is inherent in the SPF algorithm,which OSPF (as a link-state routing protocol) uses to calculate routes.This way, a tree is built for each router with itself as the root.Trees by definition do not have loops.Extensions to this tree exist only for load-balancing reasons."
Kinsly guide plz that i cannot understand it. Thanks
OSPF has inbuilt mechanism of loop prevention with the help of SPF algorithm it runs.
Apart from that you have some features like :
The back bone area creates an one to one connection to all non backbone areas preventing a chance of loop
But what you have Area 0 connected to Area 1 and Area 2. Also there is a link between Area 1 and 2.
In this condition a rule comes into play that an ABR will reject all the type 3 LSA's coming from the non backbone areas.
Also when you have two ABR's in an are let it be R10 and R20 then both of them will reject any type 3 lsa's coming from each other.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
