08-17-2018 06:18 AM
I know there is an optional Forwarding Address field in LSA5 and LSA7 in OSPFv3 :
"Forwarding Address, if included, is a fully specified 128-bit IPv6 address representing the next hop to the destination prefix. It is included only if the F Flag is set" (Routing TCP/IP Vol2)
However, using Cisco routers I have never been able to see it specified. For example, if using a basic NSSA design with routers serving as pseudo ASBR (LSA 7-5 translator), they never set this field, in opposition with OSPFv2.
So my question: is the FA field part of the RFC but not yet implememted for OSPFv3 (on Cisco routers)? Or am I just using it wrong here?
Thomas
Solved! Go to Solution.
08-21-2018 10:04 AM
As you mentioned, the RFC makes the FA setting optional and as far as I know it is not supported in IOS.
08-21-2018 10:04 AM
