OTV in Unicast mode on ASR1000X
borman.bravo
Hi, I was wondering if anyone has a configuration example or documentation regarding configuring OTV in unicast mode on an ASR1000 router, I haven't been able to find any from Cisco, I appreciate it.
Lei Tian
Hi Borman,
Did you check the example in ASR 1k configuration guide?
http://www.cisco.com/en/US/docs/ios-xml/ios/wan_otv/configuration/xe-3s/wan-otv-adj-server.html
HTH,
Lei Tian
Yes, thanks and I did see the Unicast part, there are only a couple of configuration statements under the interface overlay configuration so I'm assuming I should just remove the multicast portion of the previous multicast configuration example and use these two statements instead? so everything else stays the same?
Lei Tian
Yes, only need the interface commands. The configure for internal interface,join interface are similar, without the multicast control/data group.
HTH,
Lei Tian
Aries Fernandes
Just in case you are looking at configurations related to OTV [unicast], you can visit one of the blogs I have written related to OTV unicast-core specifically for ASR1K.
http://stayinginit.blogspot.in/2013/12/basic-unicast-overlay-transport.html
