iBGP/eBGP default route propagation
Todd Bren
Hi guys, see the attached diagram for these question:
What routers will receive udpates originated on the routers below supposing each node has default BGP configurations (and no sync enabled)?
  • Route originated on A
  • Route originated on C
  • Route originated on E
  • Route originated on H
Is the below correct?
Route A:
  • received on C only
  • missing on the rest
Route C:
  • received on A, D, E, F, G, H, I, J, K
  • missing on B only
Route E:
  • received on C, H, I, F, J, K, G, D
  • missing on A, B
Route H:
  • received on E, C, I, F, D, J, K, G
  • missing on A, B
Thank you.
Hi Todd,
In that case:
Route originated on A: Received by C only, not forwarded further
Route originated on C: Received by A, D, E, forwarded from E to H, from H to I, from I to J and F but F will drop it (AS_PATH), from J to K, from K to G but G will drop it (AS_PATH). Resulting set: A, D, E, H, I, J, K
Route originated on E: Received by C and H, forwarded from H to I, from I to J and F but F will drop it (AS_PATH), from J to K, from K to G but G will drop it (AS_PATH). Resulting set: C, H, I, J, K
Route originated on H: Received by E and I, forwarded from E to C and from I to F, forwarded from F to D, forwarded from I to J, from J to K, from K to G, from G to D. Resulting set: E, I, C, F, D, J, K, G
Best regards,
Peter
Peter Paluch
Hi Todd,
In your exhibit, the links interconnecting the routers are physical links or BGP peerings? In other words, how are the BGP adjacencies configured - which routers are BGP peers and which are not? This is crucial to answer your question correctly.
Best regards,
Peter
All interlinks are one hop BGP peerings.
Hi Todd,
In that case:
Best regards,
Peter
