Bookmark
Subscribe
6632
OTV on DMVPN
Muhammed AKYUZ
we are getting L3 MPLS service from ISP. ISP do not provide Multicast Routing. For that reason I will run multicast on DMVPN GRE tunnels. My questions is does OTV works on DMVPN interfaces?
thank you.
Peter Paluch
Hi Muhammed,
I have not personally deployed this. However, considering the fact that all OTV traffic should be IP-encapsulated, for DMVPN, it should be just another IP traffic to carry across. So in my personal opinion, it should work. Obviously, the MTU issues arising from additional layer of GRE+IP headers will have to be deal with.
Best regards,
Peter
20 Replies 20
Peter Paluch
Hi Muhammed,
Best regards,
Peter
Hi Peter,
nice to see you here after networkers...
I can deal with the MTU. I will try on ASR routers if i have chance to get routers. I will inform you about the results.
Take care.
Hi Muhammed,
It's good to see you, too! Please keep me informed - I would like very much to see if there were any major issues running the OTV over DMVPN.
Best regards,
Peter
I managed to work normal OTV. but after specifying join interface as DMVPN tunnel OTV did not work. EIGRP which is based on multicast works but OTV not.
my configuration:
otv site bridge-domain 1
otv site-identifier 0000.0000.0005
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key SIFRE address 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set TRANS esp-3des esp-sha-hmac
mode transport
crypto ipsec fragmentation after-encryption
crypto ipsec profile CRYPTO-PROFILE
set security-association lifetime seconds 900
set transform-set TRANS
interface Tunnel10
ip address 172.1.1.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 1
no ip split-horizon eigrp 1
ip pim passive
ip nhrp authentication NHRP_KEY
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 450
ip tcp adjust-mss 1360
ip igmp version 3
tunnel source GigabitEthernet1/1/0
tunnel mode gre multipoint
tunnel key 100
tunnel path-mtu-discovery
tunnel protection ipsec profile CRYPTO-PROFILE shared
interface Overlay2
no ip address
otv control-group 225.0.0.1
otv data-group 232.0.0.0/8
otv join-interface Tunnel10
service instance 200 ethernet
  encapsulation dot1q 200
  bridge-domain 200
interface GigabitEthernet1/1/0
ip address 12.12.12.1 255.255.255.0
negotiation auto
cdp enable
interface GigabitEthernet1/1/1
no ip address
negotiation auto
cdp enable
service instance 1 ethernet
  encapsulation untagged
  bridge-domain 1
service instance 201 ethernet
  bridge-domain 200
interface GigabitEthernet0
vrf forwarding Mgmt-intf
ip address 1.1.1.1 255.255.255.0
negotiation auto
router eigrp 1
network 0.0.0.0
passive-interface GigabitEthernet1/1/0
ip pim ssm default
Hello Muhammed,
Perhaps the problem is caused by the missing multicast mappings in NHRP cache on the tunnel interfaces. You see, the ip nhrp map multicast dynamic command is intended to be used on NHS hub router to add all registered NBMA address to multicast mappings automatically. However, its effect on spoke routers may not be sufficient - either it does not automatically add discovered NBMA addresses to multicast mappings (and even if it does, spoke routers would need first to communicate with all other spokes to learn about their NBMA addresses), or it reacts only the NHRP registrations - something that spoke routers never receive.
Can you try entering all multicast mappings on spoke routers statically, i.e.
interface Tunnel10
ip nhrp map multicast X.X.X.X
ip nhrp map multicast Y.Y.Y.Y
for all other spoke router NBMA addresses?
Best regards,
Peter
Muhammed AKYUZ
Hi Peter,
i have done that config on spoke side. Eigrp works ok on dmvpn. it means multicast traffic should work. cisco responded me: otv works on core multicast. what is core multicast?
Hi Muhammed,
I apologize but I am not exactly sure about the configuration changes you performed. Can you perhaps post a sanitized configuration of the GRE multipoint interface both from your hub and one spoke router please?
Regarding the Cisco's answer: I am not sure what they mean by "core multicast" and speculations won't help here. Did they tell you anything more?
Best regards,
Peter
Muhammed AKYUZ
mm
I have received this resonse from support:
Overlay Transport Virtualization (OTV) on Cisco ASR 1000 needs core multicast support. Here's the configuration guide for the OTV feature on the ASR1000 for IOS XE 3.5S:
Wide-Area Networking Configuration Guide: Overlay Transport Virtualization, Cisco IOS XE Release 3S - Configuring Overlay Transport Virtualization
http://www.cisco.com/en/US/docs/ios-xml/ios/wan_otv/configuration/xe-3s/wan-otv-confg.html
Hello Muhammed,
I guess what the support is saying is that the core network that interconnects your data centers should be multicast-enabled. However, they do not say that DMVPN is unsupported and the DMVPN itself can be considered multicast-enabled because it behaves as a single network segment.
Once again, please, be so kind to post the configuration of the tunnel interface on your hub router and on one of your spokes (assuming the spokes are identically configured). Thank you!
Best regards,
Peter
hi Peter,
spoke configuration is like this:
encr 3des
mode transport
interface Tunnel10
ip address 172.1.1.3 255.255.255.0
no ip redirects
ip mtu 1400
ip pim passive
ip nhrp map 172.1.1.1 12.12.12.1
ip nhrp map multicast 12.12.12.1
ip nhrp nhs 172.1.1.1
ip nhrp registration timeout 30
ip igmp version 3
tunnel key 100
interface Overlay2
no ip address
  bridge-domain 200
Hello Muhammed,
Thank you! So what I would like to ask you to do is to add additional mapping commands on spoke routers that map other spokes' real addresses with multicast flag, so that when a spoke sends a multicast packet over the DMVPN cloud, it will be replicated to all other spokes. Assuming that there are 4 spokes with addresses 1.1.1.1, 2.2.2.2, 3.3.3.3 and 4.4.4.4, respectively, you would add on Spoke 1:
interface Tun10
ip nhrp map multicast 2.2.2.2
ip nhrp map multicast 3.3.3.3
ip nhrp map multicast 4.4.4.4
on Spoke 2:
interface Tun10
ip nhrp map multicast 1.1.1.1
on Spoke 3:
interface Tun10
and on Spoke 4:
interface Tun10
I know this is not a scalable solution at all and it defeats the dynamic mapping nature of DMVPN - but at least we should be able to verify if the OTV is capable of running over DMVPN in this state.
I know that you have objected that EIGRP uses multicasts and works fine. That is true, however, in DMVPN, EIGRP (and other routing protocols) in fact work only in a hub-and-spoke fashion. Spoke routers do not usually communicate in the routing protocol directly. What we need for OTV is a full multicast connectivity.
Best regards,
Peter
Hi Peter,
in my lab, there are 2 ASR routers. One is hub another one is spoker. I am not able to get more than 2 ASRs. So There are 1 hub and 1 spoke. I have sent the hub and spoke dmvpn config. On dmvpn config i have tried also pim dense mode and sparse mode, works fine. But OTV mutlicasr doesn not work. I have started OTV debug, ASR sends multicast but does not receive join messages.
Also i have tried simle GRE tunnel. It did not work also.
If you have time on Monday, i can show you remotly at my demo lab.
Hello Muhammed,
I see now, thanks. (It would have been easier if you described the topology earlier but never mind.)
My fundamental interest now lies in discovering whether the multicasted OTV messages are carried via the DMVPN tunnel from hub to spoke, whether they are correctly received and processed there, and whether the responses make it correctly back to the hub.
What's interesting is the fact that not even a point-to-point GRE tunnel worked. If you connected the routers with just a plain direct cable with no tunnels, would they be capable of establishing the OTV connection correctly - with the identical config, just referencing a different join interface?
Best regards,
Peter
Muhammed,
One more thing: can you try removing the IPsec configuration for the time being, and leave just the basic unencrypted/unprotected GRE without IPsec? There was another (unresolved) post regarding OTV over GRE that suggested that without IPsec, it worked, but it stopped working after using the IPsec.
Best regards,
Peter
