output drop
cannone78
Hi all,
I've my 3845 with a giga interface configured 100M/Full Duplex.
I've applied an Hierarchical Policy with a policy parent that shape traffic at 20M and the child that manage 3 different classes with CBWFQ.
With show interface I see different output drops:
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 347
but with show policy-map interface I haven't any drop in any class even in default class..
For me output drops on phisical interface should be the amount of drops of all the classes? I'm confused..I've no crc,error...
Many thanks in advance for your support
6 Replies 6
paolo bevilacqua
Do the drops increase while traffic is flowing ? Do the packet counters in show policy-map appears to be correct ?
Thanks for your answer.
Here you are the show on my router:
sh policy-map interface gi0/0
GigabitEthernet0/0
Service-policy output: SHAPING-OUT
Class-map: class-default (match-any)
231065 packets, 95744568 bytes
30 second offered rate 2939000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
20000000/20000000 125000 500000 500000 25 62500
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 231577 96095374 2445 1565883 no
Service-policy : LLQ
Class-map: TRANSAZIONI (match-any)
182374 packets, 75496969 bytes
30 second offered rate 2358000 bps, drop rate 0 bps
Match: access-group name TRANSAZIONI
30 second rate 2358000 bps
QoS Set
precedence 4
Packets marked 182374
Queueing
Output Queue: Conversation 267
Bandwidth 8000 (kbps)Max Threshold 3000 (packets)
(pkts matched/bytes matched) 419/199692
(depth/total drops/no-buffer drops) 0/0/0
Class-map: MULTICAST (match-any)
9919 packets, 1709230 bytes
30 second offered rate 18000 bps, drop rate 0 bps
Match: access-group name MULTICAST
30 second rate 18000 bps
QoS Set
precedence 2
Packets marked 9916
Queueing
Output Queue: Conversation 265
Bandwidth 11500 (kbps)Max Threshold 4000 (packets)
(pkts matched/bytes matched) 1479/1007435
Class-map: NETWORK-CONTROL (match-all)
66 packets, 4337 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp cs6 (48)
Queueing
Output Queue: Conversation 266
Bandwidth 100 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
38706 packets, 18534032 bytes
30 second offered rate 564000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
sh int gi0/0
GigabitEthernet0/0 is up, line protocol is up
reliability 255/255, txload 40/255, rxload 6/255
Keepalive not set
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:04:46
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 482000 bits/sec, 495 packets/sec
30 second output rate 3167000 bits/sec, 2002 packets/sec
152371 packets input, 17211008 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 145 multicast, 0 pause input
229956 packets output, 95137103 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Gianluca
Now you see Total output drops 0 since i have done a clear counter...
Gianluca
All seems good. Perhaps a transient situation caused the drops.
ok...but the question is: why I see output drops on phisical interface and no drops on the show policy map?
I mean..if the policy seems no drop traffic..why theese packet are dropped on phisical interface?
Many thanks for your support...
What might be happening is the drops happened within the shaper's queues.
Yes, one assumes the parent shaper kicks over rate traffic into the child queues, and it does, but it's unclear how the two queues, parent's and child's, interact.
On some routers using hierarchal policy maps, I recall I've seen traffic queued in both the parent shaper's queues, which appears to use FQ, and the child's class defined queues.
