01-08-2013 10:13 AM - edited 03-04-2019 06:38 PM
Hi Everyone,
4500 device has config for GRE only.
I cleared the counters but drops are incrementing rapidly
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 192.168.130.254 (Loopback3), destination 192.168.128.254
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1476 bytes
Last input never, output never, output hang never
Last clearing of "show interface" counters 02:44:05
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2125
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec*******
5 minute output rate 0 bits/sec, 0 packets/sec************
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2125 packets output, 127500 bytes, 0 underruns
Here it does not show much data going via tunnel
Tunnel config is
interface Tunnel1
ip address 192.168.124.2 255.255.255.252
delay 7
tunnel source Loopback3
tunnel destination 192.168.128.254
Need to know why total drops are incrementing and how can i check if data is passing via tunnel as currenlty transmit and receive load is empty.
thanks
mahesh
Solved! Go to Solution.
01-09-2013 06:27 AM
Have you verified the connection to the other end through the tunnel interface? does it works? I see that the value of packets on output and that is being dropped have the same value, can you try to set the mtu value on the tunnel to 1400 and see if this solve your issue with the drops.
My assumption to your question regarding the input ouput rates are 0 is because there is no traffic able to pass through that interface yet. The most common reasons of output drop on tunnel are MTU, CPU and encapsulation failure.
01-09-2013 06:27 AM
01-09-2013 12:41 PM
Hi Rudy,
Thanks for reply back.
I did more digging and found that the tunnel is not in use.
Its has no config on remote end.
Mahesh
