Overlapping - different subnet mask on the same router?
rma123456789
Hi!
I have an overlapping problem.
Router 1 - on g0/0/0 has ip add 192.168.1.1/16 and on g0/0/1
I want to choose the
192.168.0.1/24 ip
add. Here is the overlap. It is possible to keep the /16 subnet mask? What is the solution?
Hi @rma123456789
 If your router supports VRF, it would be the only solution.  Put each interface in a different VRF.
https://study-ccnp.com/cisco-vrf-virtual-routing-forwarding/
5 Replies 5
M02@rt37
Hello @rma123456789,
You say want to choose the
192.168.0.1/24 ip add
This is a mandatory choice?
/16 in a router interface is not common. /30 for interco between routers are better choice.
Best regards
It is mandatory. Maybe If I use NAT it will works (to keep the /16 subnet mask)?
@rma123456789,
NAT is apply to flow in ingress or/and egress to interface(s).
Here you want to configure static IP address on an interface / same subnet as an other interface ; overlap issue.
Best regards
Hi @rma123456789
rma123456789
My router doesn't supports VRF, I will subnet the /16 mask. Thank you for the answer, I learned something new today.
