07-25-2023 02:05 PM - edited 08-03-2023 10:41 AM
Hello!
I recently upgrade an ASR 9901 from version 7.3.2 to version 7.5.2, the version was installed, but when issue the command show install active from admin I do not see the same information, do you know what is the problem. Please help me to figure this out
Solved! Go to Solution.
07-25-2023
10:28 PM
- last edited on
07-27-2023
09:57 PM
by
Translator
Hello @schizoidman8,
No problem with your ASR 9901 or the upgrade process.
In the first CLI session, you are in the RP context, and you see the output of show install active for both the RP and LC nodes. In this output, you can see that multiple packages are listed for both RP and LC.
In the second CLI session, you are in the
sysadmin
context, and you see the output of show install active for the
sysadmin-vm
view. This view only shows the packages related to the
sysadmin
image, not the full set of packages running on the router. In this output, you see only the
asr9k-sysadmin-7.5.2
package listed.
The reason for this difference is that the
sysadmin-vm
view shows the packages related to the
sysadmin
process, which is responsible for the
sysadmin
shell and other
sysadmin
related tasks. This view does not include the full set of packages running on the router, which includes IOS XR packages.
07-25-2023
10:28 PM
- last edited on
07-27-2023
09:57 PM
by
Translator
sysadmin
sysadmin-vm
sysadmin
package listed.
sysadmin-vm
sysadmin
sysadmin
shell and other
sysadmin
