Packet Generator for DSCP marking
Gerard Gacusan
Anyone uses packet generator either windows or linux? Trying to determine dscp markings end-to-end ...
I know extended ping works directly from the router but i'm wanting to generate from the client side.
thanks in advance
Gerard
3 Accepted Solutions
andrew.prince
Level 10
Level 10
I use "PingPlotter" you can set the TOS in the ICMP header.
HTH>
All Ping implementations  should be capable of setting ToS and so no need  for anything special.
Regards.
Alain.
Hi gerard,
Alain is right. If you are looking at a windows machine then you should be able to see the various options
M:\>ping
Usage: ping [-t] [-a] [-n count] [-l size] [-f] [-i TTL] [-v TOS]
            [-r count] [-s count] [[-j host-list] | [-k host-list]]
            [-w timeout] target_name
Options:
    -t             Ping the specified host until stopped.
                   To see statistics and continue - type Control-Break;
                   To stop - type Control-C.
    -a             Resolve addresses to hostnames.
    -n count       Number of echo requests to send.
    -l size        Send buffer size.
    -f             Set Don't Fragment flag in packet.
    -i TTL         Time To Live.
    -v TOS         Type Of Service.
    -r count       Record route for count hops.
    -s count       Timestamp for count hops.
    -j host-list   Loose source route along host-list.
    -k host-list   Strict source route along host-list.
    -w timeout     Timeout in milliseconds to wait for each reply.
HTH,
regards
Please rafe if helpful
10 Replies 10
andrew.prince
Level 10
Level 10
HTH>
Regards.
Alain.
Hi gerard,
M:\>ping
Options:
HTH,
regards
Great Help guys ... yeah i see it. Thanks all !
By default ALL windows OS have that option disabled.  You need to change the registry to enable TOS options to ICMP.
You need to change the "DisableUserTOSSetting" to 0
Hi Andrew,
I've just tried with a Windows xp sp2 with registry untouched and it worked.
Regards.
Alain.
Are you guys using this setting from a Vista OS? Is it a Decimal value 1-255? Also, by default the registry is already set to 0. So, I guess nothing to worry about the reg DWORD value.
Examples:
c:\ping -v 46 x.x.x.x (EF Traffic)
c:\ping -v 10 x.x.x.x (AF11 Traffic)
Wondering what this message meant for - Type Of Service (IPv4-only. This setting has been deprecated
                   and has no effect on the type of service field in the IP Header).
C:\>ping
            [-w timeout] [-R] [-S srcaddr] [-4] [-6] target_name
-v TOS        Type Of Service (IPv4-only. This setting has been deprecated
andrew.prince
Level 10
Level 10
You need to use the TOS value which is required, DSCP * 4 = TOS
So in your examples - they need to change
c:\ping -v 184 x.x.x.x (EF Traffic)
c:\ping -v 40 x.x.x.x (AF11 Traffic)
HTH>
oh ok, let me try this one... i think this one work.Yeah i was wondering why i can't see those markings
You have to multiply your  DSCP values by 4 because ToS is coded on 8 bits and DSCP on 6 bits so
EF is DSCP 46(decimal) so in binary with 6 bits 101110 and  it gives 10111000 (8+16+32+128 = 184) for ToS byte.
Regards.
Alain.
