Packet loss when MTU is set to 1450 to 1500 in cisco 2911 router
Abdur Rahim
Hi, When I try to ping setting MTU 1450 to 1500 from my Cisco 2911 router to my PC, It shows about a 10% loss. The other MTU size doesn't have any problem. My connection is P2P. All three interfaces show this problem. Please help me.
ping 1450 with IP head 20 bytes it OK, unless you modify the ip mut of interface, did you modify the default value ?
My problem was solved when I connect the router to my existing Cisco switch. I did a p2p connection and a default route. Maybe the issue is with the NIC of my PC which didn't support that MTU. What do you think?
