SPA-1X10GE-L-V2 in ASR1002-X
johnlloyd_13
Level 9
Level 9
hi,
i got a spare SPA-1X10GE-L-V2 and would like to insert/use this 1x 10G module/card in a spare slot in ASR1002-x.
my question is, is this OIR/hot swap module that ASR1002-x will auto recognize?
or do i need to reload ASR1002-x for the module to be detected? any CLI command to issue?
 It is OIR as informed on the Datasheet:
" Support for command-line interface (CLI)-controlled online insertion and removal (OIR)"
As an Small Form-Factor Pluggable [XFP], you should follow the attached document
