packet lost
Toss Leey
I have two routers configure both interface with mtu 1900, but when i ping from one side to another with mtu higher than 1510 i get higher loss packets, any idea How i can fix?
5 Replies 5
Richard Burts
What kind of media connects the routers? What kind of interfaces are the routers using? Is there any device connected between the routers or are they back to back connections?
Rick
Rick
Between them ISP but we connect them using L2TP, and both interfaces are Gig-ethernet
If between the routers is ISP then I wonder if ISP is dropping packets with large MTU. Even with L2TP if your router sends a packet with size greater than 1510 it seems the ISP would see the larger frame and might reject it.
Rick
Rick
actually the ISP use 9000 mtu
up..up..
