Bookmark
Subscribe
8814
Packet Tracer - ASA NAT Problem
shugonaka
Hi all,
I created a simple network in Cisco Packet Tracer for testing a simulated internet access with an ASA5506 and a L3 switch.
I am trying to get PC0 ping 8.8.8.8 through the network but it fails with "Request timed out".
ASA0 can ping 8.8.8.8
Core L3 Switch has ip routing enabled.
Core L3 Switch can ping ASA0 and 8.8.8.8.
PC0 can ping Core L3 Switch and ASA0 inside interface but not outside interface.
8.8.8.8 can ping ASA0 outside interface.
When Core L3 Switch ping 8.8.8.8, I see a NAT translation in sh xlate command but when PC0 ping 8.8.8.8, nothing shows in sh xlate. So I am guessing it's a NAT problem but I can't seem to find the culprit despite it's a simple setup.
Here's the applicable ASA0 and the Core L3 SW config.
ASA0:
interface GigabitEthernet1/1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet1/2
nameif outside
security-level 0
ip address 100.100.100.2 255.255.255.252
object network obj-lan
subnet 10.0.0.0 255.0.0.0
route outside 0.0.0.0 0.0.0.0 100.100.100.1 1
route inside 10.16.18.0 255.255.255.0 10.10.10.2 1
access-list acl-inside-out extended permit ip any any
access-list acl-outside-in extended permit icmp any any
access-group acl-inside-out in interface inside
access-group acl-outside-in in interface outside
nat (inside,outside) dynamic interface
Core L3 Switch:
no ip cef
ip routing
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet1/0/1
switchport access vlan 18
switchport mode access
switchport nonegotiate
interface GigabitEthernet1/0/24
switchport access vlan 10
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0001.428a.5e01
ip address 10.10.10.2 255.255.255.0
interface Vlan18
mac-address 0001.428a.5e02
ip address 10.16.18.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip flow-export version 9
2 Accepted Solutions
jalejand
You are likely hitting a packet tracer bug. Your configuration is fine.
Tried it on VIRL and it works:
ciscoasa# show xlate
1 in use, 1 most used
Flags: D - DNS, e - extended, I - identity, i - dynamic, r - portmap,
s - static, T - twice, N - net-to-net
ICMP PAT from inside:10.10.10.2/0 to outside:100.100.100.2/25215 flags ri idle 0:00:00 timeout 0:00:30
2 in use, 2 most used
ICMP PAT from inside:10.10.10.2/0 to outside:100.100.100.2/25215 flags ri idle 0:00:09 timeout 0:00:30
ICMP PAT from inside:10.16.18.10/1 to outside:100.100.100.2/1 flags ri idle 0:00:00 timeout 0:00:30
ciscoasa#
Int config:
ASA Version 9.9(2)
hostname ciscoasa
enable password $sha512$5000$LIuEniMbWtxU/3PSRiZerg==$UYUOp3RHITaZuEGhJOKe8Q== pbkdf2
names
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address 100.100.100.2 255.255.255.0
interface GigabitEthernet0/1
 nameif inside
 security-level 100
Router 2 has a loopack with your LAN subnet 10.16.18.0/24
Router 1 has a loopback with 8.8.8.8
LAN segments are the same.
14 Replies 14
post your Packet Tracer project (.pkt) file, zip it first otherwise the system won't let you upload it...
Attached is the Packet Tracer pkt file. Thanks!
This is looking as Packet tracer bug and NAT is not working due to bug.  I am getting untranslated packet on the router as
ICMP: echo reply sent, src 100.100.100.1, dst 10.16.18.10
ciscoasa#sho xlate
0 in use, 0 most used
ciscoasa#sho nat
Auto NAT Policies (Section 2)
1 (inside) to (outside) source dynamic obj-lan interface
translate_hits = 0, untranslate_hits = 0
2 (inside) to (outside) source dynamic obj-lan2 interface
(Tried with some custome object also).
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
jalejand
ciscoasa#
Int config:
ASA Version 9.9(2)
hostname ciscoasa
names
 nameif outside
 security-level 0
 nameif inside
 security-level 100
Thanks for looking into it! I'm glad it's not the config. Is there a Cisco portal to report and request for the big fix?
Thanks for the link! Appreciate it.
on a side note, if you use the 5505 instead of the 5506-X and make some configuration changes, you can get it to work. I have attached the adapted project file where I replaced the 5506-X with the 5505. On the Core L3 Switch, make sure you configure 'ip proxy-arp' under interface Vlan 10 (it won't show up in the running config). On the ASA, change the mask of the inside interface to 255.0.0.0, so it matches your network object 'obj-lan':
Core L3 Switch
interface Vlan10
--> ip proxy-arp
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
--> connected to Core L3 Switch
interface Ethernet0/1
--> connected to ISP Router
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
no nameif
no security-level
no ip address
shutdown
interface Vlan2
nameif outside
security-level 0
interface Vlan10
nameif inside
security-level 100
ip address 10.10.10.1 255.0.0.0
route inside 10.0.0.0 255.0.0.0 10.10.10.2 1
access-list IP extended permit ip any any
access-list ICMP extended permit icmp any any
access-group IP in interface inside
access-group ICMP in interface outside
class-map icmp-class
match default-inspection-traffic
policy-map icmp_policy
class icmp-class
inspect icmp
service-policy icmp_policy global
telnet timeout 5
ssh timeout 5
@Georg PauwenThis is a great workaround! I will give it a try. Thank you!
@Georg Pauwen,So I replaced ASA5506 with 5505 and made changes on the config per your suggestion but ping from PC0 still does not pass through the ASA. It is not being NAT'd. Ping from Core L3 Switch to outside still works as expected.
Maybe it's PT version specific bug? I have version 7.2.2.0418.
post the zipped project file with the 5505, I want to see if it works in my version...
Also, did you open the file I sent (I reattached it) ? Does that not work either ?
I am using version 7.2.2.0418 by the way...
Hi @Georg Pauwen
It is tested with 5505 and it is working. I also tested in the morning and your lab also. But we are facing this issue with 5506. I am not sure why but NATing is not happening.
The inspection may block the return traffic but as per debug logs, I am getting PC0 IP as the source on the router (ISP) in the ICMP packet.
Deepak Kumar,
@Georg Pauwen @Deepak Kumar, I just tested the rev.pkt and NAT was working. I went back into my pkt file again to find the differences and found nothing. I then ping from PC0 to 8.8.8.8 and it went through this time. It was NAT'd correctly on the ASA. Not sure why it did not work last night. In any case, thanks again for your time and help!
