Packet tracer for school project
Stevegood
2 computer rooms, 2 lecture rooms, server room, wifi for students and a separate one for teachers. This is the project i need to do. Maybe is someone who can help me. I've already done most of it, I can't get on with the wifi part. i dont know how to begin so help is very much needed. I send my project
Thank you in advance
check this. it gives step by step wifi configurations in packet tracer
https://www.computernetworkingnotes.com/ccna-study-guide/how-to-configure-wireless-network-in-packet-tracer.html
Good luck
KB
12 Replies 12
Good luck
KB
post the instructions you are following. You have unused Vlans, and an apparently misconfigured DHCP pool, which causes all IP addressing to be wrong. I switched the default gateway to 192.168.1.1 (which seems to be the interface on the ASA), and the DNS server address to 192.168.1.2. I set all devices (except for the RFID) to DHCP, so at least all devices get the correct IP address, and have connectivity. What exactly is the 'wifi part' you are having problems with ?
Attached the revised file.
Stevegood
you replaced the ZIP file ? I opened it, it contains two projects which essentially look the same. Do you have any written instructions that explain what you have/need to accomplish ? Basically, it is unclear what you need help with. Where are the wireless access points supposed to be ?
Stevegood
I have added a WiFi client (laptop) to each of the access points. Each access point has a different SSID. The laptops basically need the WPN module, they will then connect with the matching SSID.
Stevegood
Wouldn't it be better to do it this way?
Can I think wrong?
one access point with two SSIDs is certainly a possibility as well. As there are no instructions on how to implement this, you can use one or multiple access points, it seems to me...
Stevegood
Will it be good in the way I presented it and the professor will not have any reservations about passing the project?
what are the prerequisites and conditions for passing this project ?
Stevegood
