how to implement PIM SM on switch
kingstdz
Hello
I have video flow udp://ip@port injected on vlanx switch cisco 9200 witch differents vlan
this switch is connected to topology until switch core 9500
i want to view ud://ip@port in another vlany who can ping hosts under vlanx (who content video streaming channel)
hosts off same vlanx can view but hosts vlany no, i will use PIM SM to have streaming video in vlan y or other.
please help me
thanks
balaji.bandi
how is your Multicast config on both the Cat 9200 ? is this working on same VLAN first ? before you extend to other switch ?
what client you using - most case by default TTL 1 that need to increase to reach the media server
good example thread :
https://community.cisco.com/t5/switching/multicast-streaming-video-with-vlc-across-vlans-routers/td-p/1753789
BB
hi thanks for your replay
how is your Multicast config on both the Cat 9200 ? i haven't idea but igmp exist
is this working on same VLAN first? yes they have all same vlans (16, 39,...)
please can guide me more ? i have ikusi flow i wan to get the streaming in other vlan, i have route between vlan (inter vlan )
thanks
check the video help you to setup :
https://www.youtube.com/watch?v=Gjt2L9jAYNA
BB
Multicast Routing on Cisco Routers (for CCNA, CCNP, and CCIE Candidates) http://kwtrain.com/mcast Click Link Above to Receive more Cisco Routing and Switching. ===================================================== In this video, you'll learn multicast theory and configuration for Cisco routers ...
post a schematic drawing of your topology showing how all devices involved are connected, as well as the running configurations (sh run) of all devices involved.
