Packet tracer ISR-4331 set gig0/0/0 to use sfp instead of copper int
davehouser1
The ISR-4331 has two SFP
interfaces gig0/0/1
you can add an SFP and it works by default.
However
 gig0/0/0
will not work with an SFP by default, the interface is set to use the RJ45 copper port by default.
How do I switch
gig0/0/0
to use the SFP interface instead?
davehouser1
Figured it out. Needed to go into the interface on the 4331, and change the `media-type`. Interface came right up after.
$ conf t
# interface gig0/0/0
# media-type sfp
in the attached file, I have configured both
GigabitEthernet0/0/0
ports as media type RJ-45, and connected both ports with a copper cable. The connection works fine. What exactly is not working in your setup, can you post the relevant (zipped) Packet Tracer project (.pkt) file ?
As I said in the previous post, I want
gig0/0/0
to use the fiber SFP port, not the RJ45 port, but it does not work. I think I need to adjust a setting to tell the router to use the SFP port instead of the rj45 port for
gig0/0/0.
I want both
gig0/0/0 and gig0/0/1
to use SFP ports not rj45.
davehouser1
$ conf t
# media-type sfp
I will complement this answer, in tracert package it is mandatory to select whether it is SFP or RJ45, with the "media-type" command in the configuration interface, but in a real ISR 4331, there is an additional command (by default) "auto-select" , and identifies the type of media that has been connected...
