Packet Tracer routing doesn't work
ngaoiwnwa2
Hello all, unfortunately I'm stuck and I don't know what to do.
I configured the switches:
  • created VLAN 10,20
  • trunk with vlan trunk allowed vlan 1,10,20 between the firstfloor and secondfloor switches
  • trunk from secondfloor switch to router
  • added clients to their vlan
  • created subinterfaces on the router
  • added encapsulation on the subinterfaces for g0/0/0.20 and .10 for VLAN 20 and VLAN 10
  • created p2p interface between routers with /30 mask
I can ping from vlan 10 to vlan 20 on the left and right side of the topology. Unfortunately I can't ping to the other side and I'm pretty much sure there's a routing problem so the packet can't flow over from 10.10.10.1 -> 10.10.10.2
I also created a static route:
  • Network: 192.168.1.0
    mask: 255.255.255.0
  • next hop: 10.10.10.2 on router 10.10.10.1 on reverse on the other side
Do I somehow have to enable a trunk between both routers?
Help is really appreciated because I'm stuck and I've been trying this for about 2 hours now.
M02@rt37
Hello @ngaoiwnwa2
Impossible to do that like this.
Routers route network/subnet. On Router0 you have the subnet 192.168.2.0/24  directly connected and you have a static route towards Router1 to reach this same subnet.....
And if you do a #show ip route on that Router0 you will see that subnet 192.168.2.0/24 is know only as connected networks...
Same logic on Router1.
You could have same vlan id on that 2 sites, because VLAN is locally significant, but you have to configure different subnets on the 2 sites attached to these vlan.
As an example:
on the right you should have vlan10: 192.168.1.0/25 and vlan20: 192.168.2.0/25
on the left you should have vlan10: 192.168.1.128/25 and vlan20: 192.168.2.128/25
Adjust ip static routes on Routers 0 and 1 as concerned the mask and the different Gateways.
Best regards
6 Replies 6
Mark Elsen
              - FYI Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Blue_Bird
Hello ngaoiwnwa2,
Check once again with Ip addressing scheme for the topology... I think...It is not correct.
Each router should be configured with defferent network and different ip addresses...
Best regards
******* If This Helps, Please Rate *******
This does not seem to be correct. Both are connected and both are on a /30 subnet. If I give the other router another network, the router does not know where it goes AFAIK.
M02@rt37
Hello @ngaoiwnwa2
As an example:
Best regards
Thanks for explaination. I figured it out myself that I can't have the same network on both sides because I assume the router gets confused by both the same default gateway. So AFAIK if I understand it correctly it routes from Router 0 over to Router 1 but sees that the destination has the same network / default gateway?
Could you please explain, if you don't mind, a bit deeper why this does not work? I still don't understand it 100%.
@ngaoiwnwa2
When a router receives a packet, it makes a routing decision based on the destination IP address. Router 0 looks into its routing table to determine the appropriate outgoing interface for the packet toward 192.168.1.15 (PC on right side as example).
Router 0 can not route a packet towards 192.169.1.15 since this same subnet is directly connected to him. Same subnet....administrative distance of connected subnet is 0 ; so the best !
Best regards
