Packet Tracer - Troubleshoot Static and Default Routes
lcc80
Hi all,
I've been given a PT file (attached) to troubleshoot for a uni module. I'm slowly getting to grips with routing, but this one has confused me.
I've worked my way through the IPv4 and IPv6 configurations and made a list of what I think is wrong. I found 8 errors. Before making any changes in PT I had a look online, and everyone else has 5 errors, which match with 5 of my 8.
R1 - Incorrect next hop IPv4 address set for default route.
R2 - Two incorrect IPv4 static routes set The next hop addresses for LAN 1 and LAN 3 are the wrong way around.
R2 - Incorrect IPv6 network address provided for LAN 1.
R3 - Incorrect IPv4 prefix/mask configured for LAN 1 network address.
R4 - There is no static IPv6 route configured for LAN 1.
I made the changes in PT based on the 5 and I have full connectivity, so that's good! But as far as I can see the following also apply...
R1 - No IPv4 static routes for LAN 2, WAN, or LAN 3.
R2 - No IPv4 default route(s) set.
R3 - No IPv4 default route set.
So that's left me confused. Does R1 *have* to have static routes if a default is set, and do R2 and R3 *have* to have defaults...? I can't check results in PT as it's locked for this activity.
Could anyone shed some light on this?
As it all works I could submit it now but I don't want to miss out on marks as I need everything I can get!
Leo
Mark Elsen
        - FYI Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
