Packet tracer Site to site VPN configuration gone
Joshua X P
I configured Site to Site VPN in Packet tracer 7.3.0 between two 2901 routers. I Saved the running Conf to startup-config. But When turn OFF and turn ON the physical switch of the router my all VPN configurations are gone in the startup-config. If I reload the router using the Reload command, I'm not facing this issue. And I'm not facing this with 4321 routers.
I believe this could be a bug. Correct me If I'm wrong
Joshua X P
same here, so it seems to be a bug indeed. It seems to still be in the startup-config after the power down/up (sh startup-config). If you do a 'copy startup-config running-config' after the powe down/up, it should be back...
could be a bug indeed. Can you post the zipped .pkt file ?
Hi Georg,
Thanks for your reply!
Here I attached the Zipped .pkt file
Joshua X P
Thanks for the solution!
I hope Cisco would fix this bug in next update.
