packets are not encrypting/decrypting using GRE OVER IPSEC
prabinchand
I am doing GRE OVER  IPSEC but not able to encrypt and decrypt packets..
configuraiton is all right from my side.
NOTE: topology is attached below.
CONFIGURATION
HQ
HQ(config)#do sh run
Building configuration...
Current configuration : 1575 bytes
version 15.2
hostname HQ
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key admin address 2.2.2.2
crypto ipsec transform-set adminset esp-3des esp-md5-hmac
mode tunnel
crypto map adminmap 1 ipsec-isakmp
set peer 2.2.2.2
set transform-set adminset
match address GRE
interface Tunnel1
ip address 172.16.10.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 2.2.2.2
interface FastEthernet0/0
ip address 1.1.1.2 255.255.255.0
speed auto
duplex auto
crypto map adminmap
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 192.168.20.0 255.255.255.0 172.16.10.2
ip access-list extended GRE
permit gre host 192.168.10.2 host 192.168.20.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
BR
BR(config)#DO SH RUN
version 15.2
hostname BR
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
crypto isakmp key admin address 1.1.1.2
mode tunnel
set peer 1.1.1.2
match address GRE
interface Tunnel1
ip address 172.16.10.2 255.255.255.0
tunnel source FastEthernet1/1
tunnel destination 1.1.1.2
no ip address
shutdown
speed auto
duplex auto
ip address 192.168.20.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.2 255.255.255.0
speed auto
duplex auto
crypto map adminmap
no ip http server
ip route 0.0.0.0 0.0.0.0 2.2.2.1
ip route 192.168.20.0 255.255.255.0 172.16.10.1
permit gre host 192.168.20.2 host 192.168.10.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
ISP
ISP(config)#do sh run
Current configuration : 1040 bytes
version 15.2
hostname ISP
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 1.1.1.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.1 255.255.255.0
speed auto
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip route 0.0.0.0 0.0.0.0 2.2.2.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
2 Accepted Solutions
Seb Rupik
Hi there,
If you want the GRE tunnel to form via the IPSec tunnel then you need to update your 'GRE' crytpo ACL to permit the traffic between the GRE tunnel endpoints. Delete the existing ACL on HQ and BRANCH and replace with. Also add a dynamic IGP into the mix to advertise routes via the GRE tunnel.
!! HQ
permit gre host 1.1.1.2 host 2.2.2.2
ip route 2.2.2.2 0.0.0.0 1.1.1.1
router eigrp 1
network 172.16.10 0.0.0.255
network 192.168.10. 0.0.0.255
!! BRANCH
permit gre host 2.2.2.2 host 1.1.1.2
ip route 1.1.1.2 0.0.0.0 2.2.2.1
router eigrp 1
cheers,
Seb.
Deepak Kumar
In your original configuration, you are using GRE over IPsec so you need to adjust your interested ACL "GRE" accordingly.
<<<HQ>>>
<<<BRANCH>>>
It is not necessary to use Dynamic routing and static routing also works fine.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
Seb Rupik
Hi there,
!! HQ
router eigrp 1
!! BRANCH
router eigrp 1
cheers,
Seb.
hello respected sir,
is it necessary to use dynamic routing while using gre over ipsec or what ??
i have used static, therefore it didn't worked sir ??
aslo access-list has the host ip of router interface why ??? i didn't get that
please clearify me, i'm new to this networking field sir.
Hi there,
One of the benefits of using a GRE tunnel is that it can encapsulate multicast traffic, this means it can then be used for carrying IGP traffic. Static routes are fine if you are using contigious IP addressing at either sites which lends itself to address summarisation. However if you don't have well defined addressing at either sites then setting up multiple static routes will become an admin overhead. Using an IGP reduces this workload for you.
We chance the GRE ACL to list the 'outside' interface IPs at either site, as when a GRE packets egress that interface they are identified by the crypto map and sent via the IPSec tunnel.
cheers,
Seb.
Deepak Kumar
<<<HQ>>>
<<<BRANCH>>>
Deepak Kumar,
access-list has the host ip of router interface, why??? i didn't it
will you help me clarifying it.?
