tunnel is up but protocol is down, using IPSEC OVER GRE
prabinchand
hello troubleshooters !
i am facing the problem while performing IPSEC OVER GRE. On both router HQ & BR tunnels are up but protocols is down. Configuration is all right from my side.
NOTE: topology is attached below.
CONFIGURATION
ISP
ISP(config)#do sh run
Building configuration...
Current configuration : 1040 bytes
version 15.2
hostname ISP
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 3.3.3.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet0/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
ip address 6.6.6.1 255.255.255.0
speed auto
duplex auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 3.3.3.2
ip route 0.0.0.0 0.0.0.0 6.6.6.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
HQ
HQ(config)#do sh run
Current configuration : 1503 bytes
version 15.2
hostname HQ
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key admin address 6.6.6.2
crypto ipsec transform-set adminset esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile SECURE
set transform-set adminset
interface Tunnel1
ip address 172.12.12.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 172.12.12.2
tunnel protection ipsec profile SECURE
ip address 3.3.3.2 255.255.255.0
speed auto
duplex auto
ip address 192.168.10.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 1
network 172.12.12.0 0.0.0.255
network 192.168.10.0
no ip http server
ip route 6.6.6.0 255.255.255.0 3.3.3.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
BR
BR(config)#do sh run
version 15.2
hostname BR
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
crypto isakmp key admin address 3.3.3.2
mode tunnel
interface Tunnel1
ip address 172.12.12.2 255.255.255.0
tunnel source FastEthernet1/1
tunnel destination 172.12.12.1
no ip address
shutdown
speed auto
duplex auto
ip address 192.168.20.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 6.6.6.2 255.255.255.0
speed auto
duplex auto
router eigrp 1
network 192.168.20.0
no ip http server
ip route 3.3.3.0 255.255.255.0 6.6.6.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
2 Accepted Solutions
Hello
Your tunnel destination should not be the tunnel interface ip the opposite rtr it should point to isp routable address of its peer.
Kind Regards
Paul
make the changes marked in bold:
HQ
interface Tunnel1
--> tunnel destination 6.6.6.2
BR
interface Tunnel1
--> tunnel destination 3.3.3.2
Hello
Kind Regards
Paul
HQ
interface Tunnel1
BR
interface Tunnel1
