Can't apply PBR on Nexus 9300
AK59
Dear all,
I'm actually stuck implementing PBR on a N9K.
I have 4 x C93180LC-EX, 1 cluster of 2 in one site, the other cluster of 2 in another site.
Both are connected via vPC, the configurations seems  pretty similars.
Both sites have FEX members
I have to implement PBR.
The "route-map" is based on an ACL permitting packets coming from one subnet to public destination, the action is to route it a "next-hop" which is a remote firewall.
The problem is that I have been able to implement it only on one cluster...when I tried to implement on both members of the other cluster, I get this message
% Could not apply PBR route-map - Redirect not supported for one of a configured next-hop
Can someone know how to deal with it ?
Thanks in advance,
Little update, we finally found the cause of the problem.
With Nexus 9300 EX series, you can't do PBR with interfaces on FEX.
Our "next-hop" was on FEX interfaces , that's why it didn't work.
As soon as we changed it and put the next hop on another core router, it worked.
7 Replies 7
follow
can you post the route map, as well as a drawing of your topology ?
AK59
You'll find attached the scheme.
The policy route map say that if the flow comes from sources server to a specified destination, then set the next hop to VIP 1 .
I can only see what you post. What does the other route map look like, and what is the difference between the next hops specified in both route maps ?
Post the content of both route maps.
AK59
Here is the summary
Creating the access-list
N9K# configure terminal
N9K(config)# ip access-list ACL
N9K(config-acl)# permit ip 10.1.1.0 0.0.0.255  11.0.0.0 0.255.255.255
Creating the route-map policy
N9K(config)# route-map PBR
N9K(config-route-map)#  match ip address ACL
N9K(config-route-map)#  set ip next-hop 10.2.2.2 (that's my VIP )
Applying the route-map
N9K(config)#  int vlan 5
N9K(config-if)#  ip policy route-map PBR
I do the exact same configuration on the 4 Nexus...
what if you add the "load-share" option:
set ip next-hop 10.2.2.2 load-share
