PacketTracer 4 subnets for beginners advice
icebowl-1967
I teach networking fundamentals and I curious about different methods of implementing subnets.
We are using PackettTracer 7.3.1.
I want the students to create a network with 4 subnets
192.168.1.0/26
What would be some possible Cisco Hardware (ROUTERS and SWITCHES) options?
most (if not all) routers in Packet Tracer have only 3 (max) layer 3 interfaces. What you could do is take e.g. a 4331 router, and create subinterfaces on one of the interfaces, than connect a switch with 4 Vlans, and trunk that switch to the router. That introduces a bunch of stuff right away, such as Vlans, trunking, subnetting, inter-Vlan routing, etc.
Attached a sample file with 4 subnets/Vlans based on the 192.168.1.0/24 address space.
You are a Super Hero.  Thank you!
Martin L
You can use any router to build so called Router os a stick with Dot1Q encapsulation on sub-interfaces
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/0.10
encapsulation dot1Q 10 native
ip address 20.0.0.2 255.255.255.0
interface GigabitEthernet0/0.40
encapsulation dot1Q 40
ip address 30.0.0.2 255.255.255.0
and so on
see example of PT ROAS in https://learningnetwork.cisco.com/s/question/0D53i00000zHyP8CAK/vlan-configuration-pro-2
"Dot1Q encapsulation on sub-interfaces"
Thank you for the response.
Homework begins!
