Page cannot be displayed Cisco 877
crmljc1976
I keep getting a page cannot be displayed error in IE 7 on certain webpages, but when I refresh the page it downloads successfully. I cant find the solution anywhere. Would anyone know why this happens. Here is my cisco 877 config.
sh run
Building configuration...
Current configuration : 1642 bytes
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
ip subnet-zero
ip cef
ip name-server 194.72.6.57
no ftp-server write-enable
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip mtu 1458
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxx@xxxx.btclick.com
ppp chap password 0 xxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source static 192.168.1.2 111.111.111.111
ip dns server
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0
password xxxxx
login
transport input all
line vty 1 4
login
transport input all
scheduler max-task-time 5000
end
Router#
a.alekseev
Level 7
Level 7
try
conf t
int d0
ip tcp adjust-mss 1380
Aleksey,
The "ip tcp mss-adjust" command goes under vlan1, not dialer.
However, it appears that the problem is cause by the arbitrary "ip mtu" command put under dialer. This is PPPoA, not PPPoE and normally no MTU reduction is necessary.
The command should be removed in first place, then to verify, ping something with size 1500 and DF bit set.
