Passing OSPF routing -- R1 --> Checkpoint FW -- R2
metzj
What would be the best way to configure OSPF Routing to pass from R1 thru Checkpoint FW to R2 without establishing a GRE Tunnel. I have attmepted this via ethernet interfaces configured with "ip ospf network non-broadcast" command. Specifying neigbhor commands in the OSPF process. Also we are using secondary ip address. I have attached the configs of the two routers. So far All I get on R2 is attempt/drother. Any suggestions are most welcome.
Harold Ritter
Joel,
As far as I know, you will only be able to get an adjacency between R1 and R2 if you configure the transparent mode on the Checkpoint FW1 platform. I know this is the case when you use a Cisco FW service module (FWSM).
In routed mode, you will simply not be able to achieve that as the OSPF packets are sent with a TTL of 1 and decremented on the Checkpoint device.
Thank You "hritter" I appreciate the insight with our problem. What is the best way to route through a firewall with a Cisco router on each side.
Thank You
Joel,
As mentioned in my previous post, the best way would probably be to use the transparent mode on the Checkpoint FW-1 device, which would allow you to have an adjacency between R1 and R2.
If you don't want to go from routed to transparent mode, then I would recommend to run BGP through the FW and to redistribute between OSPF and BGP on either side.
Joel,
Are you trying to run OSPF with the Checkpoint firewall? I've done this and it worked well. There was an FWSM on the inside and a 2600 router on the outside.
If not, what's your reason for not letting the Checkpoint participate in OSPF?
Keith
Co-Founder LinuxDynasty
http://www.linuxdynasty.org
http://www.linuxdynasty.com
