10-19-2007 04:52 AM - edited 03-03-2019 07:14 PM
I have the following network setup: 2 network elements connected together with an OC3/STM1 link. In beween there is an OC3/STM1 network tap that mirrors the traffic. My question is now: is it possible to put this (passiv) link into a Cisco switch and e.g. mirror it to different ethernet ports. Especially does Cisco keep OC3/STM1 links up that do not have any active handshaking or keep alive signaling (port is not allowed/able to send any data into the network).
Solved! Go to Solution.
10-21-2007 08:57 AM
Yes, absolutely. I think the passive device can mirror one direction at once, anyway.
10-19-2007 09:45 AM
Yes, it possible by disabling keepalives on the interface.The matter is that when you want to send into ethernet, the protocol must be routable, or bridgeable.
10-21-2007 04:49 AM
Thank you for the answer. First part (disabling keepalive) is OK. Second part: The connection is an ethernet over sonet connection. I am not a sonet expert but I thought of something like putting an OC3/STM1 link into somthing like a VLAN and monitor it on ethernet ports. Is this possible?
10-21-2007 08:57 AM
