11-17-2021 08:22 AM
Can a passive RFID tag be removed from the C9300 switch? Also, what does it look like if it can
be removed? I would appreciate any help with this, as I can't find enough information on Cisco's site.
Thank you.
11-18-2021 06:26 AM - edited 11-18-2021 06:34 AM
Radio Frequency Identification (RFID) on Cisco Catalyst 9000 Family Switches White Paper
The Cisco Catalyst 9200, 9300 and 9500 Series, which are one-rack-unit (1RU) switches, have one built-in RFID
tag in the front panel of the switch. The modular Cisco Catalyst 9400 and 9600 Series chassis features built-in RFID
on several system components: the supervisor, line card, and fan tray. The RFID tag on the Cisco Catalyst 9400 and
9600 Series line cards are embedded in the ejector arm handle (Figure 4)
an rfid tag may have several forms, well known forms are
- a flat RFID tag -> a "sticker" with a coil connected to a chip
- a tube like RFID tag which can be mounted inside a plastic element, as in the aboive mentioned "handle"
11-18-2021 08:53 AM
it is a physical chip, if you open the chassis, you void all warranties.
You can disable the feature in the software:
C9300(config)# no location rfid status
