Password Recovery / 7606-S with RSP720-3C-GE
Eric Flahaut
Hello.  I would like to request assistance with a password recovery.
I am working on a Cisco 7606-S Switch and a 7600 Series Route Switch Processor 720 with Multilayer Switch Feature Card.
I have copied the newest IOS (c7600rsp72043-adventerprisek9-mz.155-3.S8.bin) to a newly formatted flash card.  I use this image to boot the cards from ROMMON.
The problem is this, the cards boot successfully with the IOS, however an old configuration loads with the IOS and the credentials are unknown.
I have used the "confreg 0x2102" and other "confreg 0x0" options with the same outcome.  I have removed all flash media disks from disk1, and the two internal flash media disks from the card.  All of these options result in the loading of the old configuration with the new IOS.
How can I remove this configuration and clean boot from the newly downloaded IOS.
Thank you in advance for your help.
10 Replies 10
Leo Laohoo
0x2102 is not password-recovery mode.  This instructs the system to read the configuration.
0x2142 instructs the system to ignore the configuration and boot into ROMmon.  This is how to start the password-recovery process.
Kindly read Password Recovery Procedure for the Catalyst 6500 with Supervisor 720 Running Cisco IOS Software.
Thank you for the suggestion.
I have tried the "confreg 0x2142" in the past and again, just now, with the same result.  Once the switch boots with the new IOS, it reads a configuration from "somewhere" and loads this configuration into memory.
I don't know where this configuration is saved.  As before I have removed all memory cards from the external disk slots and the internal disk slots.
Any other ideas are greatly appreciated.
Here hoping someone has found a solution to this problem. I'm having the same issue and I have tried many different confreg boot modes.
I've also tried swapping the flash cards on the internal system with one that was working fine, but the configuration is still loaded on somehow, so I cant reset the NVRAM.
Please if anyone has found a solution or has better ideas to reply.
Post the complete output to the command "sh version".
Drake-7609>show ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 02-Oct-10 18:39 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD5, RELEASE SOFTWARE (fc2)
Drake-7609 uptime is 2 minutes
Uptime for this control processor is 2 minutes
System returned to ROM by power cycle (SP by power on)
System image file is "sup-bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRD5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 917504K/65536K bytes of memory.
Processor board ID FOX1545GUE1
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
7 Virtual Ethernet interfaces
2 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Drake-7609>
This is what I got, I went into Rommon and set it back to 0x2142 (see attached files) and then booted into the disk and got the same thing.
In both of your text files the config register is 0x2102. The config register needs to be 0x2142 to avoid the existing config
Rick
Right! I changed it in rommon but it changes back to 0x2102 when it boots. And since I don't know the password to enable I cannot configure it from the terminal...
Carllarson,
It has been so long ago, that I don't remember exactly.  But I seem to recall the backup supervisor card was installed and the router was pulling a config from that device and loading it into memory.  I hope this helps and good luck.
I'll look into that, thank you!
Hi Carl,
I hope you found a solution, if not, I think i may of, it's a matter of timing, if you issue a break command whilst in Switch Processor mode the confreg is not a recognized command and 5 seconds too late after switching to the route processor the config is loaded even though the you issue the confreg 0x2142 in rommon so it appears to have pulled the config through from "somewhere" in short as soon as you see the "*Jan 4 11:23:50.211: %OIR-6-CONSOLE: Changing console ownership to route processor" do the break command and then follow as below and you should be just fine!
regards Colin
Cisco IOS Software, c7600rsp72043_sp Software (c7600rsp72043_sp-ADVIPSERVICESK9-M), Version 12.2(33)SRE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 15-Sep-11 03:27 by prod_rel_team
*Jan 4 11:23:50.211: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan 4 11:23:49.627: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C7600-RSP720/RP platform with 1048576 Kbytes of main memory
rommon 1 > confreg 0x2142
You must reset or power cycle for new config to take effect
rommon 2 > reset
Resetting .......
Download Start
Download Completed! Booting the image.
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE5, RELEASE SOFTWARE (fc1)
Compiled Thu 15-Sep-11 03:20 by prod_rel_team
export@cisco.com.
Cisco CISCO7609-S (M8500) processor (revision 1.0) with 917504K/65536K bytes of memory.
Processor board ID FOX1518G3Q9
BASEBOARD: RSP720
Last reset from s/w reset
1 Virtual Ethernet interface
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
*Jan 4 11:24:57.547: RP: Currently running ROMMON from S (Gold) region
*Jan 4 11:24:57.671: %MLS_RATE-6-ENABLING_RL_DEFAULT: TTL rate-limiter is set to default value
*Jan 4 11:24:57.671: %MLS_RATE-6-ENABLING_RL_DEFAULT: MTU rate-limiter is set to default value
*Jan 4 11:24:57.907: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 4 11:25:05.723: %SYS-5-RESTART: System restarted --
*Jan 4 11:23:50.519: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 30-Jun-11 13:52 by integ Build [100]
*Jan 4 11:24:15.175: %ONLINE-SP-6-DNLDFAIL: Module 6, Proc. 1, Runtime image download failed because of scp send failure
*Jan 4 11:24:54.879: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 4 11:24:55.079: SP: SP: Currently running ROMMON from S (Gold) region
*Jan 4 11:25:05.915: %SYS-SP-5-RESTART: System restarted --
*Jan 4 11:25:07.895: %OIR-SP-6-INSPS: Power supply inserted in slot 1
*Jan 4 11:25:07.899: %C7600_PWR-SP-4-PSOK: power supply 1 turned on.
*Jan 4 11:25:10.484: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Jan 4 11:25:10.568: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6 became active.
*Jan 4 11:25:12.521: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
*Jan 4 11:25:16.751: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
*Jan 4 11:25:17.127: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
Router>en
Router#ter len 0
Router#wr er
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
Router#
*Jan 4 11:25:40.831: %SYS-SP-7-NV_BLOCK_INIT: Initialized the geometry of nvram
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#config-
Router(config)#config-register 0x2102
Router(config)#^Z
Router#re
*Jan 4 11:26:00.255: %SYS-5-CONFIG_I: Configured from console by consoleload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
