PASSWORD RECOVERY ON Cisco ISR 4331 is DISABLED
dissai
DEAR COMMUNITY
  • How can I reset my router password since I found recovery mode is disabled.
    I am using console to access it. Break it failed with console to go to rommon mode
Use a USB Type A to mini-USB console cable because the Ctrl+Break may not work.
7 Replies 7
Hi MHM
My problem. I don’t remember password.
when I tried to break it tell me PASSWORD RECOVERY IS DISABLED.
DI
no service password-recovery <<- I think this feature is disable that why you can not do password recovery.
I will check how we can recover from this command first.
MHM
HI MHM
Thank you I will be waiting
Leo Laohoo
Console into the router and post the entire boot-up process.
What type of console cable are you using (USB-to-serial cable, USB Type A to USB micro)?
What type of console session are you using (example:  PuTTY)?
Hi Leo,
The console cable is a USB-to-serial cable, and in the console session, we
use putty.
