PAT configuration in Packet Tracer 6.2
oarga_mihai1
I'm having trouble with setting up PAT in packet tracer. The problem is that if i set up PAT i can no access the http server. With static nat everything is ok. Can you give me a hint what i'm doing wrong?
Building configuration...
Current configuration : 823 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524G3J2
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 1.0.0.2 255.255.255.252
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 2.0.0.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 10
network 2.0.0.0
network 1.0.0.0
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip classless
ip flow-export version 9
access-list 1 permit 10.0.0.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Borgenstrand
I can see that you are doing PAT on CopyRouter4 according to your topology.
As it is now, the PC do not know which IP the Server-PT is using. If you want the Server to have a public IP address, you need to use static NAT so you know which IP address it is using. You can give it 2.0.0.1:80 or 2.0.0.1:443 if you want to give it just a port-number instead of the entire IP address.
Hello
Youll need a Nat static to identify a specific port to nat towards, As PAT wont know what to translate to without it.
So if there is only one HTTP destination device then you can add a static defining the outside interface and inside ip address of the http server and port number, However is their are multiple destination inside your network then you can do the same but using different inside host and port number
ip nat inside source static tcp x.x.x.x interface gig0/1 80
ip nat inside source static tcp x.x.x.x interface gig0/1 8080
or as you have already stated, you can use individual statics  with individual public addressing (thats if you have public ips free to use)
ip nat inside source static tcp  x.x.x.x 80 2.0.0.5 80
ip nat inside source static tcp  x.x.x.x 80 2.0.0.6 80
res
Paul
Kind Regards
Paul
