Pat configuration on Router
Hello
I need a PAT configuration for 2 networks inside to 2 different global adresses. So how can i make this?
So one internal network should pat to one global adress and the other network to the second global adress.
I only can configure pat to the interface or a global pool. When i take the pool the router would take some kind of global adresses.
pleas help me
37 Replies 37
Jon Marshall
You just make the pool contain only one address eg -
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 102 permit ip 192.168.3.0 0.0.0.255 any
ip nat pool <name-1> 195.77.10.2 195.77.10.2 netmask 255.255.255.252
ip nat pool <name-2> 195.77.10.3 195.77.10.3 netmask 255.255.255.252
ip nat inside source list 101 pool <name-1> overload
ip nat inside source list 102 pool <name-2> overload
the netmask in the pool is only used to check your IPs are within the range it doesn't mean you actually use all the IPs.
Jon
This is what i thought at first but i thought i could not insert only one ip in the pool.
I have tested it this weekend but it did not work. The first pool works but the second did not work.
The Ip`s and the subnets are ok. When i change the nat to translate it to the interface it works but with the wrong global ip.
pls help me
Can you post the configuration you used ?
Jon
ip nat pool Internal 80.123.101.126 80.123.101.126 netmask 255.255.255.252
ip nat pool Wlan 80.123.101.127 80.123.101.127 netmask 255.255.255.252
ip nat inside source list 100 pool Internal overload
ip nat inside source list 101 pool Wlan overload
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
interface FastEthernet0/0.1
 description *****Intern*****
 encapsulation dot1Q 10
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface FastEthernet0/0.2
 description *****WLAN*****
 encapsulation dot1Q 20
 ip access-group Wlan in
 ip nat inside
interface FastEthernet0/1
 description *****WAN*****
 ip address 80.123.101.126 255.255.255.248
 ip access-group Outside_in in
 ip verify unicast reverse-path
 ip inspect Firewall in
 ip nat outside
 duplex auto
 speed auto
I can't see why that wouldn't work to be honest.
I will test it out when I get the chance (later today) but as far as I can see it should have worked fine.
What device/IOS version are you using ?
Did you check the translation table when you tried to connect from both subnets ?
Jon
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
This is my software version
I checked the nat translation. The Inside network was ok but on the wlan i have no entry.
Maybe the subnet was to small and the global ip`s are to close ???
Raimund
Raimund
Just tested this and as expected it works fine.
You have an acl on your WLAN interface, could that be blocking the packets ?
Jon
I have tested it without the acl and than i insert it on the interface.
This acl is only for blocking wlan to the internal network.
ip access-list extended Wlan
 permit ip any host 192.168.0.8
 permit ip host 192.168.1.100 any
 permit ip host 192.168.1.101 any
 permit ip host 192.168.1.102 any
 permit ip host 192.168.1.103 any
 deny   ip any 192.168.0.0 0.0.0.255
 permit ip any any
Don't know what to say really.
I have used this before and even tested it just to make sure.
When you try to connect what does the translation table show ?
Jon
Testrouter#show ip nat translations
Testrouter#
nothing on wlan interface
when i switch to intern everything is working.
Can you pls post your config?
My configuration is pretty much the NAT setup and basic connectivity between a L3 switch and some routers.
Are you sure this a NAT problem and not basic connectivity from that subnet ?
Can you ping the default gateway from a client on that subnet ?
Jon
I think i found the problem
I have a cisco 1841 with a 4ESW Switchport interface. When i connect the fe0/1 port on the router it will work with the pool address. I made a vlan on the switchport with a interface and ip. Then i configure the vlan interface as inside and insert a nat with a pool adress. This doesn`t work. When i change the Nat to the interface fa0/0 (outside) it works.
Do you have any idea why?  It seems to me that the switchport can only NAT to an interface and not to a pool. Strange
000631: *Feb  3 11:53:40.822: NAT: translation failed (A), dropping packet s=192.168.3.10 d=64.233.166.94
000632: *Feb  3 11:53:41.554: NAT: translation failed (A), dropping packet s=192.168.3.10 d=192.168.20.50
000633: *Feb  3 11:53:43.550: NAT: translation failed (A), dropping packet s=192.168.3.10 d=192.168.20.50
000634: *Feb  3 11:53:44.566: NAT: translation failed (A), dropping packet s=192.168.3.10 d=192.168.20.50
Raimund
I'm confused by your output because it is referencing 192.168.3.x IPs but you don't have these anywhere in your configuration.
Can you clarify ?
Jon
