Pat configuration on Router
Hello
I need a PAT configuration for 2 networks inside to 2 different global adresses. So how can i make this?
So one internal network should pat to one global adress and the other network to the second global adress.
I only can configure pat to the interface or a global pool. When i take the pool the router would take some kind of global adresses.
pleas help me
37 Replies 37
You may have just missed this from the configuration you posted but you do not have "ip nat inside" under your fa0/1.1 interface.
Jon
oh yes i see. But still no NAT.
When i change the NAT to interface it will work. when i change it to pool every NAT translations a deleted.
Hmmm not good
Your last configuration only has NAT setup for the interface.
Can you just try this -
1) add in NAT for both pools as in your earlier config
2) before trying any connectivity can you make sure you clear all existing translations ie.
"clear ip translations *"
Jon
Now i found the problem. If i change the pool addresses with start and end ip to the same it will not work.
When i took 2 different Ip´s it is working. I think that it is not possible that the start and end ip can be the same.
Hmmm
It should be because all the tests I did were with one IP per pool.
Maybe you have hit a bug.
Jon
I made this but no result. Nat is not possible.  I´m not so good in configure cisco because i`m learning for my CCNA.
Maybe i have a missunderstanding in NAT and PAT.
I don't think you do have a misunderstanding because the configurations you have tried work fine for me.
I think the issue is with the hardware not your configuration.
Jon
I don't think this is a NAT issue.
I tested a variety of different ways and it always works.
I have never used one of those switch modules but I think the issue is that they do not have a backplane connection to the router ie. they cannot route between the vlan interfaces and the onboard ports.
I believe some switch modules can but I couldn't find any documentation about it for the 1841.
So what I would suggest is you run a cable from a spare interface on your switch module to the fa0/1 inbuilt Ethernet port, remove the vlan interfaces and then create subinterfaces on the physical interface and try again.
Jon
