pat on ios
acomiskey
Level 10
Level 10
IOS newbie here trying to pat inside hosts to the address on e1/0.
I'm sure there's not much to it, any help would be great. Thanks everyone.
9 Replies 9
R1(config)#ip nat inside source list 100 interface e1/0 overload
R1(config)#access-list 100 permit ip any any
R1(config)#int e1/0
R1(config-if)#ip nat outside
R1(config-if)#int e0/0
R1(config-if)#ip nat inside
Am sure you know if you want to be specific about the inside network to be NATted then change the access list accordingly.
Sundar
Thanks, so this is really how it is. Would it still be the same. Should e1/0 be "ip nat outside"?
Hosts inside FastEthernet0/0 are going out through e1/0.
Oops sorry e1/0 should be outside. I corrected my previous post to reflect that.
You are correct. This is the IOS equivalent of the PIX global (outside) 1 interface command.
Sundar
No problems, I figured it was just a typo.
Jon Marshall
Hi Adam
If inside hosts are 192.168.1.0 255.255.255.0 and assuming they connect on e0/0 interface
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface e1/0 overload
interface e0/0
ip nat inside
interface e1/0
ip nat outside
Jon
Thanks guys...
I had
access-list 1 permit 0.0.0.0
and it didn't work?
Adam,
I believe you need to use an extended access list for NAT in IOS. Although I may have seen it work with a standard access list.
Glad you got it to work :-)
Sundar
Hi Sundar
You can use a normal access-list with NAT on IOS. Extended access-lists are useful if you want to do policy NAT.
Jon
Jon,
I thought so but I wasn't positive about it.
Apparently the reason why the standard ACL Adam using wasn't working is because it was showing as 'host 0.0.0.0' rather than 'any'.
Sundar
