PAT problem
teymur azimov
we have a problem. we have a router which performs NAT, and behind router we have ASA. in inside we have a server. we need requests which come to our outside interface with port number 9000 convert to server ip with port number 443. we do port address translation on router :
ip nat inside source static tcp 192.168.10.10 443 interface GigabitEthernet0/0 9000
and on ASA we permit everything for test.
but our config doesnt work. what should we do?
cadet alain
can you provide the config of the ASA.
Regards.
Alain.
ASA Version 8.2(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list 111 extended permit ip 192.168.1.0 255.255.255.0 192.168.20.0 255.25        5.255.0
access-list out_to_in extended permit tcp any host 192.168.10.10 eq smtp
access-list out_to_in extended permit tcp any host 192.168.10.10 eq www
access-list out_to_in extended permit tcp any host 192.168.10.10 eq https
pager lines 24
logging enable
logging timestamp
logging list my-list level debugging class vpn
logging trap my-list
logging host inside 192.168.1.10
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list 111
access-group out_to_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
route inside 192.168.1.0 255.255.255.0 172.16.100.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server CiscoAsa protocol radius
aaa-server CiscoAsa (inside) host 192.168.1.10
key 1q2w!1q2w
radius-common-pw 1q2w!1q2w
http server enable
http 10.0.0.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set RA-TS esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYN_MAP 10 set transform-set RA-TS
crypto map VPN_MAP 30 ipsec-isakmp dynamic DYN_MAP
crypto map VPN_MAP interface outside
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 3600
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
no vpn-addr-assign local
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy RAVPN internal
group-policy RAVPN attributes
dns-server value 192.168.1.10
dhcp-network-scope 192.168.20.0
vpn-idle-timeout 45
username risk password WJjW/emCr.pCrXeq encrypted
tunnel-group vpnclient type remote-access
tunnel-group vpnclient general-attributes
authentication-server-group CiscoAsa
default-group-policy RAVPN
dhcp-server 192.168.1.10
tunnel-group vpnclient ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:e49b92e97309f3e2767d8c8ad29f9c14
: end
Can you provide show ip nat translation output from your router as well? Most important to look at is, if the translation is happening. There could be a chance that the traffic is really not coming in with Port 9000 on the router. Hence translation doesnt happen.
Router#show ip nat translations
Pro Inside global      Inside local                   Outside local           Outside global
tcp 172.16.10.2:9000   192.168.10.10:443     172.16.10.1:1902     172.16.10.1:1902
tcp 172.16.10.2:9000   192.168.10.10:443  ---                ---
and asa access-list:
access-list out_to_in line 1 extended permit tcp any host 192.168.10.10 eq smtp (hitcnt=1) 0x8c8a5270
access-list out_to_in line 3 extended permit tcp any host 192.168.10.10 eq www (hitcnt=0) 0x66a8840a
access-list out_to_in line 4 extended permit tcp any host 192.168.10.10 eq https (hitcnt=5) 0x66546073
