01-23-2012 12:01 AM - edited 03-04-2019 02:59 PM
I am attaching packet tracer file "Routing Rip Example.pkt". in which i connected few routers and configured networks using two classe of IPs, Class C and ClassA all using same subnet mask /24,pis is here http://i.lulzimg.com/1b225f6042.png and the problem is Router0's routing table has entry 10.0.0.0/8 like this http://i.lulzimg.com/ce24f3ec3a.png , why there is only one entry of 10's network having /8 entry despite of i have two 10's network configured /24 ??
01-23-2012 12:37 AM
if you want to see both 10's /24 networks you'll have to:
-enable rip v2 on r2:
router rip
ver 2
- disable auto-summarization
router rip
no auto
then on r0: clear ip route * and sh ip route rip will show you the /24 networks.
Regards.
Alain
01-23-2012 12:47 AM
the reason is, that RIPv1 will summmarize your networks at a class-full boundary, which means that a Class-A network will always get a /8. This is a internal process on your Router because RIPv1 does not send any Subnetmasks within it's updates.
So,
your router is getting a update for a network 10.0.0.0 (<- without any subnetmask) and will assign a /8 automatically, because 10.0.0.0 is in the Class-A range.
Using RIPv2 would solve the problem
Cadet Alain explained how to configure it!
regards
BTW: Please rate, if helpful!
01-23-2012 01:04 AM
@cadet alain and @Dirk Woellhaf
Thanks for your replies..however my problem doesn't see to get solved, here is the example to Networks topology along with the networks ID in the pic
The Routing table of router1 is as follows
Here all is good, all subnet of 10's are showing along with /24 mask, which i configured in real, neither i used rip v2, nor disabled summarization...
01-23-2012 01:38 AM
ad "Here all is good, all subnet of 10's are showing along with /24 mask, which i configured in real, neither i used rip v2, nor disabled summarization..."
You can see the 10's routes as connected here, NOT received by RIP.
That's why the subnet mask is correct!
HTH,
Milan
01-23-2012 01:50 AM
How about Router2's routing table which has exactly same entry like Router1
01-23-2012 02:02 AM
Are you running the same IOs version on all your routers?
Which one?
HTH,
Milan
01-23-2012 02:06 AM
(C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)
01-23-2012 02:48 AM
here it is not the same output as one route is directly connected and the other learnt via RIP.
You got the correct /24 mask because you configured the same mask everywhere so the router is considering the mask of the IP address configured on the interface where the RIP update is coming.
Regards.
Alain
