PAT Statistics Counters
Sandovag123
Visitor
Hello
Regards to the command "show ip nat statistics" on an ASR1000. The increment of the counters "In-to-out drops", "Out-to-in drops" and "Port block alloc fail:" are refered to a PAT problems?  Or just are packets that don´t need to do nat?
This is an example of an output of a router ASR1000 IOS 3.08
ROUTER#show ip nat statistics
Total active translations: 89566 (0 static, 89566 dynamic; 89566 extended)
Outside interfaces:
TenGigabitEthernet0/0/1
Inside interfaces:
Tunnel12098
Hits: 6721089331 Misses: 41697444
Expired translations: 42261166
Dynamic mappings:
-- Inside Source
[Id: 1] access-list Prueba interface TenGigabitEthernet0/0/1 refcount 89563
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
In-to-out drops: 14182335 Out-to-in drops: 131221
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 4146132
IP alias add fail: 0
Limit entry add fail: 0
Cisco Freak
Level 9
Level 9
Do you have NAT rate limiting configured on you router?
CF
Hello CF
Yes, the router has the command "max-entries" This is the actual configuration:
vrf forwarding Prueba
ip address X.X.X.X 255.255.255.248
ip nat outside
interface Tunnel12098
ip address 10.111.98.1 255.255.254.0
ip nat inside
ip tcp adjust-mss 1200
tunnel source TenGigabitEthernet0/0/1
tunnel destination 10.11.255.134
ip nat inside source list NAT-LIST interface TenGigabitEthernet0/0/1 vrf Prueba overload
ip nat translation max-entries list Prueba 20000000
ip access-list extended NAT-LIST
permit ip 10.0.0.0 0.255.255.255 any
Adel3
Frequent Visitor
Frequent Visitor
Any news guys ?
