PBR and FTP protocol
We have a 2911 Cisco router with two ADSL interfaces (two Dialers). In Dialer1 we have a site-to-site VPN connection with another cisco router in a different site.
In dialer0 we have configured a policy based routing for internet feed (http, https, dns).
Default route uses Dialer1.
We want the ftp protocol to use the Dialer0 connection.
We have changed the access-list that used by our route-map so that contains ftp and ftp-data protocol but we can not use the ftp.
Is there something else that we must do?
The router's config:
interface GigabitEthernet0/0
ip address 192.168.2.241 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map INTERNET_MAP
duplex auto
speed auto
interface Dialer0
ip address x.y.z.w 255.255.255.0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
interface Dialer1
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 2
ip nat inside source route-map INTERNET_MAP interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended INTERNET_LIST
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq domain
permit udp any any eq domain
permit tcp any any eq pop3
permit tcp any any eq smtp
permit tcp any any eq ftp
permit tcp any any eq ftp-data
route-map INTERNET_MAP permit 10
match ip address INTERNET_LIST
set interface Dialer0
7 Replies 7
lgijssel
Level 9
Level 9
There is no route for interface dialer 0.
regards,
Leo
What do we have to type?
ip route 0.0.0.0 0.0.0.0 Dialer0 20
will solve the problem?
This will not interrupt the VPN?
Thanks.
I do not share the opinion of my colleague Leo that you need a default route for dialer 0. If you have the router set up with a default route using dialer 1, and if you do not intend to provide failover capability to use dialer 0 if dialer 1 has a problem (which is not indicated in your post) then I believe that having PBR send traffic to dialer 0 is sufficient.
I am not comfortable using the same route map for PBR and for NAT as is shown in the config posted. I would prefer to see a separate route map for PBR and a map for NAT. I wonder if there is some issue between the NAT for dialer 0 and the NAT for dialer 1 (assuming that there is NAT for dialer 1). Perhaps you could post a more complete version of the config that has both dialer and all NAT related configuration?
Rick
Rick
I found that when ftp uses passive mode the ports that
will be used are dynamic ports and they have been negotiated between client and server.
Probably this is the problem but what is the way to overcome this?
Whqat do I have to put in the access-list without disturbing the VPN?
This is the difference between active and passive ftp.
With passive ftp, the client negotiates the port to use and hence it will always be open on the fw.
It is also the reason why passive ftp is recommended in todays environments with numerous firewalls.
So, when it works using passive mode there is no reason to modify anything on your network components.
Using active ftp must be discouraged because it is so much harder to secure.
regards,
Leo
So, why ftp is not working from our network?
Is something missing in our config?
Something that we must add to PBR?
Q. Why does active FTP work with static and extended port forwarding, but not with PAT?
A. The reason is that when you open up the FTP connection you connect to port 21 at the remote FTP server. But when you do a "ls", "put", get", or anything that needs to use a data port, the server opens up another connection back to the client. When you open your original FTP connection from the inside and the router pretends that you are a specific outside IP, and picks a random port number to use, the FTP server thinks it is talking to that IP address and that port number. Therefore, when it needs to open up the data connection back, due to the "get" or "ls", it attempts to open a TCP connection from port 20 to a random port that the server decides. While on the outside IP it thinks it is talking to, the router hears traffic directed at its outside IP, but does not have any PAT mapping for that random port number that the server picked. Therefore, it does not know that this traffic is supposed to go back to the client.
The port 20 never gets established. The fix is to use "passive FTP" mode. Passive FTP has the client open both port 21 and port 20 connections from the start. The router knows about both of them rather than just port 21, and allows the server to open port 20.
Refer to Analysis of the File Transfer Protocol (FTP) for more information on FTP.
You need extended translations for port 20 and 21 with static mappings (example address)
ip nat inside source static tcp 192.168.0.4 20 66.46.64.82 20 extendable
ip nat inside source static tcp 192.168.0.4 21 66.46.64.82 21 extendable
The way that active FTP works does not allow for the use of dynamic NAT. Only static NAT can be used in this case. This is a limitation of FTP.
Alternatively, you can choose to policy-route all traffic for hosts accessing ftp via dialer0.
regards,
Leo
