PBR configuration
stamil
Hi ,
I am new to Cisco routers and i was trying to configure PBR in Cisco router. I was facing problem in forwarding HTTP Traffic to the cache_server. Please help me to find the rules to forward the HTTP traffic.
Tamil
7 Replies 7
Hi @stamil,
Could you please post the current PBR configuration for your Router?
Hi @Hector Gustavo Serrano Gutierrez ,
Please Take look at my config
wan --> FastEthernet2/0
LAN --> FastEthernet 1/0
Cache_iface --> FastEthernet 2/1
interface GigabitEthernet0/0
no ip address
shutdown
duplex full
speed 1000
media-type gbic
negotiation auto
interface FastEthernet1/0
ip address 192.168.50.1 255.255.255.0
ip policy route-map linux-proxy
ip nat inside
ip virtual-reassembly
duplex half
interface FastEthernet2/0
ip address 192.168.200.200 255.255.255.0
ip nat outside
ip policy route-map wan-proxy
duplex auto
speed auto
interface FastEthernet2/1
ip address 192.168.56.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet2/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip access-list extended http-traffic
permit tcp any any eq www
ip access-list extended wan-traffic
permit tcp any eq www any
access-list 1 permit 192.168.56.0 0.0.0.255
access-list 1 permit 192.168.50.0 0.0.0.255
no cdp log mismatch duplex
route-map linux-proxy permit 1
match ip address http-traffic
set ip next-hop 192.168.56.125
route-map wan-proxy permit 1
match ip address wan-traffic
This my running configuration
PBR config looks correct.
what exactly isnt working?
is traffic on port 80 hitting 192.168.156.125 at all?
Please remember to rate useful posts, by clicking on the stars below.
Hi @stamil,
I tested the configuration in VIRL. It is OK.
The Cisco Router with PBR + NAT shouldn't be the problem here.
As @Dennis Mink suggested, what do you see on that linux-proxy (192.168.156.125)?. Is it actually forwarding the HTTP request traffic back to the Router?
Cheers.
Thanks for your reply and i accept your point. In cache_box side, while running wireshark it shows these errors
  1. TCP RETRANSMISSION
  2. TCP PREVOIUS SEGMENT NOT CAPTURED
  3. TCO DUP ACK
  4. TCP ACKED UNSEEN SEGMENT
  5. TCP FAST RETRANSMISSION
  6. TCP OUT-OF-ORDER
When i google on those error the similar answer was there was multi-path between server and client
can you please help me to sort this problem, I suspect the rules are not forwarding properly.
Please provide some debug techniques to check packet flow in router level.
Hi @stamil,
Those TCP messages can be caused by many different factors, including devices beyond this Cisco Router and linux-proxy server.
What is the issue you are facing at this moment? Is it no connectivity, constant disconnections or poor performance when attempting to pass the traffic thru your linux-proxy?
The PBR configuration should be forwarding all the traffic destined to TCP port 80 to that linux-proxy.
In reverse direction, the return traffic with TCP port 80 as source, is also being forwarded to that same linux-proxy.
This is just TCP port 80 traffic (HTTP). Not DNS, not HTTPS.
Moving forward, here is how you can take packet captures on the Cisco IOS Router:
Embedded Packet Capture for Cisco IOS and IOS-XE Configuration Example
Cisco IOS Configuration Example
Hope this helps.
Seb Rupik
