PBR doesn't work on Catalyst 9300 ( VLAN Interface)
Ryan YC
Hi Guys,
I'm suffering a problem that about PBR and VLAN Interface on the Catalyst C9300-24UX, Cisco IOS XE Software, Version 16.06.03.
My question is, I created a route-map and access-list as my PBR configuration, and then applied on VLAN 1, but the PBR seems doesn't work, I even didn't see any hit count when I show route-map and didn't see the relative messages from the 'debug ip policy'
---------------The following is the part of configurations -----------------
interface Vlan1
description Server network subnet
ip address 10.99.99.10 255.255.255.240 secondary
ip address 192.168.34.252 255.255.255.0
ip policy route-map PBR_testing
access-list 110 permit ip 10.99.99.0 0.0.0.255 192.168.56.0 0.0.0.255
route-map PBR_testing permit 10
match ip address 110
set ip next-hop 192.168.34.245
---------------The following is my topology -----------------
The purpose that I want to make the client (on the left bottom side) can access the server (on the right bottom side). I'm sure the routing table has the PBR's next-hop existing.
Please help me if you have any idea, please. I spent almost two days trying to solve this issue.
13 Replies 13
post the full configuration of the switch. Do you have 'ip routing' enabled ?
Please let me know if any information is needed for this troubleshooting,  thank you!
------------------------------- The following is the configuration ---------------------------------
version 16.6
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname xxxxxxx
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 xxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization exec default local
ip routing
cpp system-default
diagnostic bootup level minimal
spanning-tree mode pvst
file privilege 5
username admin secret 5 xxxxxxxxxxxxxxxxxx
redundancy
mode sso
lldp run
interface Port-channel1
switchport mode access
interface Port-channel2
interface Port-channel3
interface Port-channel4
switchport mode trunk
interface Port-channel5
interface Port-channel6
interface Port-channel7
shutdown
interface Port-channel8
interface Port-channel9
interface Port-channel12
interface Port-channel16
interface Port-channel18
interface Port-channel19
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
speed 1000
negotiation auto
interface TenGigabitEthernet1/0/1
channel-group 1 mode on
interface TenGigabitEthernet1/0/2
interface TenGigabitEthernet1/0/3
channel-group 2 mode on
interface TenGigabitEthernet1/0/4
channel-group 6 mode on
interface TenGigabitEthernet1/0/5
channel-group 3 mode on
interface TenGigabitEthernet1/0/6
channel-group 19 mode on
interface TenGigabitEthernet1/0/7
channel-group 4 mode on
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/0/9
interface TenGigabitEthernet1/0/10
shutdown
channel-group 7 mode on
interface TenGigabitEthernet1/0/11
channel-group 8 mode on
interface TenGigabitEthernet1/0/12
channel-group 9 mode on
interface TenGigabitEthernet1/0/13
channel-group 18 mode on
interface TenGigabitEthernet1/0/14
interface TenGigabitEthernet1/0/15
channel-group 12 mode on
interface TenGigabitEthernet1/0/16
interface TenGigabitEthernet1/0/17
channel-group 16 mode on
interface TenGigabitEthernet1/0/18
interface TenGigabitEthernet1/0/19
spanning-tree portfast
interface TenGigabitEthernet1/0/20
interface TenGigabitEthernet1/0/21
interface TenGigabitEthernet1/0/22
service-policy output IP_Precedence_For_MPLS_QoS
interface TenGigabitEthernet1/0/23
interface TenGigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
load-interval 30
channel-group 5 mode on
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface TenGigabitEthernet2/0/3
interface TenGigabitEthernet2/0/4
interface TenGigabitEthernet2/0/5
interface TenGigabitEthernet2/0/6
interface TenGigabitEthernet2/0/7
interface TenGigabitEthernet2/0/8
spanning-tree bpduguard enable
interface TenGigabitEthernet2/0/9
shutdown
interface TenGigabitEthernet2/0/10
shutdown
interface TenGigabitEthernet2/0/11
shutdown
interface TenGigabitEthernet2/0/12
shutdown
interface TenGigabitEthernet2/0/13
shutdown
interface TenGigabitEthernet2/0/14
shutdown
interface TenGigabitEthernet2/0/15
interface TenGigabitEthernet2/0/16
shutdown
interface TenGigabitEthernet2/0/17
shutdown
interface TenGigabitEthernet2/0/18
shutdown
interface TenGigabitEthernet2/0/19
interface TenGigabitEthernet2/0/20
shutdown
interface TenGigabitEthernet2/0/21
shutdown
interface TenGigabitEthernet2/0/22
description DO_NOT_CONFIGURE
shutdown
interface TenGigabitEthernet2/0/23
interface TenGigabitEthernet2/0/24
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
load-interval 30
interface TenGigabitEthernet2/1/2
shutdown
interface TenGigabitEthernet2/1/3
shutdown
interface TenGigabitEthernet2/1/4
shutdown
interface TenGigabitEthernet2/1/5
shutdown
interface TenGigabitEthernet2/1/6
shutdown
interface TenGigabitEthernet2/1/7
shutdown
interface TenGigabitEthernet2/1/8
shutdown
interface FortyGigabitEthernet2/1/1
interface FortyGigabitEthernet2/1/2
interface Vlan1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.34.245
ip route 10.0.0.0 255.255.255.0 192.168.34.245
ip route 10.40.0.0 255.255.0.0 192.168.34.245
ip route 10.40.10.0 255.255.254.0 192.168.34.245
ip route 10.75.254.0 255.255.255.0 192.168.34.245
ip route 10.75.255.0 255.255.255.0 192.168.34.245
ip route 192.168.0.0 255.255.224.0 192.168.34.247
ip route 192.168.52.0 255.255.252.0 192.168.34.247
ip route 192.168.56.0 255.255.255.0 192.168.34.247
ip route 192.168.128.0 255.255.128.0 192.168.34.247
ip route 172.24.16.0 255.255.252.0 192.168.34.245
ip route 172.24.20.0 255.255.255.0 192.168.34.245
ip route 172.24.74.11 255.255.255.255 192.168.34.245
ip route 192.168.2.32 255.255.255.240 192.168.34.247
ip ssh version 2
control-plane
line con 0
exec-timeout 30 0
logging synchronous
stopbits 1
line vty 0 4
exec-timeout 60 0
logging synchronous
transport input all
line vty 5 15
exec-timeout 60 0
logging synchronous
transport input all
ntp server 192.168.34.12
end
  1.
The wildcard used in your access list 110 does not match the subnet mask of the secondary IP address on the Vlan interface. Try and change it to:
access-list 110 permit ip 10.99.99.0 0.0.0.15 192.168.56.0 0.0.0.255
Hi Georg,
I changed the wildcard mask in the access list, but the issue still same :(
This's my current only ACL in the route-map on the Interface VLAN 1:
'access-list 110 permit ip 10.99.99.0 0.0.0.15 192.168.56.0 0.0.0.255'
However after I applied the route-map onto the Interface, I can see a lot of messages from 'debug ip policy' those are reporting:
May 12 10:48:59 UTC: IP: s=192.168.34.76 (Vlan1), d=192.168.34.255, len 692, policy rejected -- normal forwarding
May 12 10:48:59 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:00 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:01 UTC: IP: s=192.168.34.20 (Vlan1), d=192.168.34.255, len 229, policy rejected -- normal forwarding
May 12 10:49:01 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:02 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:03 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:04 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:05 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:06 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:07 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:08 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:08 UTC: IP: s=192.168.34.35 (Vlan1), d=192.168.34.255, len 229, policy rejected -- normal forwarding
May 12 10:49:08 UTC: IP: s=192.168.34.51 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:09 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
May 12 10:49:10 UTC: IP: s=192.168.34.15 (Vlan1), d=192.168.34.255, len 78, policy rejected -- normal forwarding
I was continuing to ping a server in 192.168.56.0/24 subnet by using 10.99.99.1, but I didn't see any message about 10.99.99.0 subnet on the Core switch.
Hello Yung,
from the output that you have provided we can say the PBR is configured and actually skipped for all source addresses in the primary IP subnet.
Could you try to use a test in which you match a specific IP address in the primary subnet
try to use an ACL like the following
access-list 111 permit ip 192.168.34.x 0.0.0.0 192.168.56.0 0.0.0.255
I wonder if the issue is related to secondary addresses.
In old times to make PBR working in some multilayer platforms we needed to change the SDM template. I don't think it is your case as the debug lines show that the PBR is considered before using normal forwarding.
Hope to help
Giuseppe
Giuseppe
what if you make the secondary the primary and the primary the secondary IP address on your Windows NIC ?
Hi @Ryan YC
Your PBR configuration is correct and should work appropriately. The only think that I can think of is packets not getting to the right router. Can you make sure that you are using 10.99.99.10 as the gateway for the host in 10.99.99.0/28 subnet.
Also it would be helpful to apply below ACL on the interface and make sure that packets are indeed received on the right interface.
access-list 199 permit icmp host 10.99.99.1 192.168.56.0 0.0.0.255 log
access-list 199 permit ip any any
interface vlan 1
ip access-group 199 in
If the hit count on the first entry is seen and you've verified in logs that the destination is correct. Then PBR should work fine.
*** Please mark this post helpful if it contributed to your query ***
Sebastian
for PBR to work, I should expect to have multiple routes, where you want to force/prefer a specific path.
you are not using a routing protocol, and you are using a single static route to access 192.168.56.0 255.255.255.0 network on the 9300.
also you need to check both MPLS and VPN routers know the route to the 192.168.56.0 subnet?
Hello
Regards your ping my understanding the primary interface is always used as source even when you have secondary addressing assign to the same interface.
Just for clarity - you really don’t need these static routes as they are captured by the default static route
No ip route 10.0.0.0 255.255.255.0 192.168.34.245
No ip route 10.40.0.0 255.255.0.0 192.168.34.245
No ip route 10.40.10.0 255.255.254.0 192.168.34.245
No ip route 10.75.254.0 255.255.255.0 192.168.34.245
No ip route 10.75.255.0 255.255.255.0 192.168.34.245
No ip route 172.24.16.0 255.255.252.0 192.168.34.245
No ip route 172.24.20.0 255.255.255.0 192.168.34.245
Lastly could you try the following:
no access-list 110 permit ip 10.99.99.0 0.0.0.255 192.168.56.0 0.0.0.255
no route-map PBR
access-list 110 permit ip 192.168.34.0 0.0.0.255 192.168.56.0 0.0.0.255
route-map PBR_testing deny 10
route-map PBR_testing permit 99
Kind Regards
Paul
We have a post that is several months old describing an issue with PBR that received a number of suggestions and has no clear indication of whether the issue was solved or not. I found it odd in the original post that the PBR was specifying the secondary address and no mention of the primary address. And I wonder if the issue was that the device was sending using the primary address and not the secondary address. Now @Alex Pfeil says he has the same issue but provides no details. Perhaps if we get the details we might have some suggestions about his issue.
Rick
Rick
Alex Pfeil
Level 7
Level 7
Were you able to get this issue resolved? I am seeing a similar problem.
